Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13519 Discussions
Using "QuickAssist Software Acceleration" on Intel NUC 12 Pro
km9
I purchased Intel NUC 12 Pro Kit NUC12WSHi5 that uses Core i5-1240P, as it is stated on ark.intel.com that the CPU supports "Intel® QuickAssist Software Acceleration".
Doing some research, it seems to me that QuickAssist Software Acceleration is a software implementation of the Intel QAT Engine (see https://github.com/intel/QAT_Engine/blob/master/docs/software_requirements.md).
Fine.
However, when I build the library following the instructions and try to run it, it complains that the CPU is not supported:
> Processor unsupported for QAT_SW - AVX512F = 0, VAES = 1, VPCLMULQDQ = 1
What should I do to use QuickAssit Software Acceleration?
Any help is welcome. Thank you in advance.
Jean_Intel
Hello km9,
To have a better understanding of your issue, please provide me with the following:
  • Please, provide us with a screenshot of the error message you receive.
  • Also, I noticed that the article you shared mentions Linux Operating Systems (OS). Are you using a Linux OS? If so, which OS flavor and kernel version are you using?
Jean O.
Jean_Intel
Hello km9,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello km9,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
