Hello everyone,
I'm integrating the vcust tool into a solution for a manufacturing environment. The product is a NUC with Visual BIOS. I'm having problems because after executing any command that triggers the reboot trigger, confirmation is required to make changes to the motherboard BIOS (press <1> to reject and <9> to allow). It is a requirement that this confirmation should not be requested, but I have not found how to do it in the documentation. Are there any workarounds?
AFAIK, there is no workaround. It is a security requirement that this confirmation take place, so I rather doubt that they would entertain the possibility of introducing such a workaround (since it would likely affect more than just your NUCs). Still, if you would like to try, contact Intel Customer Support directly and open a ticket requesting this capability. Understand that, if they did add support for this capability, it would likely be many months before it could be made available.
