Dear Team,
Greetings!!!
For part no BXNUC10I7FNHAA1 MDDS document has conflicting data in regards to REACH regulation. REACH SVHC is above limit according to document. However calculated PPM with respect to substance weight and Product Mass '1.45 kg' is less than 1000PPM which is conflicting.
Also for below parts MDDS document does not have REACH data available in the document
NUC7I5BNH
Hello SMude, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
SMude, Thank you for posting in the Intel® Communities Support.
In reference to this scenario and this topic, we will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Hello SMude, I just received an update on this matter.
1). Article is defined by the RoHS regulation as parts of a product that the shape dictates more of its function than what it is made of. Therefore, the mass percent calculation is based on the article weight, not the total product weight. In other words for these 5 substances total products mass (1450g) shouldn’t be used in PPM calculations.
2). The Document does declare EU RoHS compliant.
REACH SVHCs are all listed in the MDDS as well. Unlike RoHS, REACH only requires declarations of REACH SVHC and we have done so in the MDDS.
Albert R.
Hello SMude, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Albert R.
