Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Very High Temperature When Playing Games
When I am playing Diablo3 for few minutes, the CPU temperature will be up to 94°C, and the fan spins at more than 5000RPM, quite noisy. Is it normal status or anything goes wrong?
NUC6i5SYH
Kingston HyperX 8G X 2
Toshiba m.2 SSD 128G
Plextor M6S 128G SATA
Highlighted
Valued Contributor I
try to lower the game video settings and see if that makes a difference.
I found when playing Half Life 2 on the highest settings caused max temp. of 92C.
I lowered the settings to Medium and now the CPU temp stays around 75C max, with a spike to 85C from time to time.
I guess your case is not exceptional.
Highlighted
Lowered the video setting to medium, but still high temperature even after 5 mins game, 88°C....
Iris 540 should deserve better video configurationT_T
Highlighted
Community Manager
Hi RoyceX,
Please run our Intel® System Support Utility and send me the results of the test.
I would like to review the current settings of your unit.
Intel® System Support Utility v2.0
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600 https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600
Mike C
Highlighted
Sorry, I can not find a button to upload the result file, so just copy the content here, you may save it into a xml file.
<?xml version="1.0"?>
1.2.0.58
08/17/2016
00:00:18.9296257
http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Graphics+540" />
<Setting id="Video Architecture" displayName="" value...
Highlighted
Community Manager
Hi RoyceX,
Thank you for your results. I suggest you the following workaround.
Get into the BIOS>Advanced>Devices>Video and change IGD Aperture Size to 1024MB, keep Minimum Memory as default: 64MB
Then, go to BIOS>Advanced>Cooling> change Fan Control mode to Cool.
In regards to the graphics driver, I suggest you to try with the Beta version 4474.
Intel® Beta Graphics Driver
https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Window... https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Window...
I suggest you to set your games according to Intel recommendations at https://gameplay.intel.com/ https://gameplay.intel.com/
There are many games already tested.
Let me know how it goes. Games require a lot of resources from the system, so it is normal to get high temperatures.
Mike C
Highlighted
Hi Mike,
Thank you for your suggestion, some questions:
1. My current graphic driver is 4481, why a older beta version driver is recommended?
2. In gameplay.intel.com, I could not find recommend configuration for Iris 540 graphic card or i5 6260U processor.
Highlighted
Highlighted
--This action really helps, it could control the temperature under 90°C when playing diablo3 now.
Highlighted
This recommendation seems under estimate Iris 540's capability, actually high performance@1080p could work with at least 30fps in the game.(Diablo3)
Highlighted
Yes, but may yield higher temps. When you're at 94°C it's not to far from TjMAX (100°C) and the CPU may start throttling.
Now that you applied the IGD aperture change, you could try and find out empirically, and perhaps post your findings to 'gameplay'?
