Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13520 Discussions
Visual BIOS Can't distinguish between 2 identical m2 SSD's NUC6i7KYK - Dual Boot
GGunn1
I have a different OS on each of my two m2 SSD's. Legacy boot should provide some way for me to distinguish between the two SSDs - to know which contains which OS. This could be a rename or description field perhaps. Perhaps there is an option that I have missed?
Hello, GramG. Thank you very much for contacting the Intel Communities Team. I will be more than happy to assist you.
In this case, the UEFI BIOS of the NUC will only show the name that the manufacturer of the SSD gave it. You can change the name of the SSDs from the OS and check them from there as well.
Antony S.
goso
did you even read the question?
goso
did you ever get the answer?
