Intel® NUCs
12121 Discussions
WMI Docs or drivers for Linux LED control for NUC8i3BE/NUC8i5BE/NUC8i7BE ( Bean Canyon)
dessa
We are looking for WMI docs for Bean Canyon models.
Neither DKMS Linux driver ( https://github.com/milesp20/intel_nuc_led) nor Hades https://github.com/nomego/intel_nuc_led work.
Gen 6/7 WMI calls report unsupported, and new Hades command doesn't seem to be completely incompatible.
dessa
Doing some test on NUC8i7BE with the latest BIOS ( the same happens on NUC8i3x)
Commands 0x1/0x2 - returns 0xE1-function not supported, return ACPI buffer type length 152 bytes
All other command (0,3,4,5,6) - return ACPI 'integer' (0)
S/W control is enabled in BIOS settings ( and RGB LEDs are not lit when s/w control is enabled)
It is almost like either BIOS or firmware is not supporting new LED WMI properly (Revision 0.64) and disabled old LED WMI ?
System Details:
Ubuntu : Linux chroma64-studio 4.15.0-20-lowlatency #21-Ubuntu SMP PREEMPT Tue Apr 24 07:52:58 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
BIOS Version 0064 - BECFL357.86A.0064.2019.0213.1122
fwts wmi - seems correct:
\AMW0._WDG (1 of 2)
 GUID: 8C5DA44C-CDC3-46B3-8619-4E26D34390B7
 WMI Method:
   Flags         : 0x02 (Method)
   Object ID     : AA
   Instance     : 0x01
PASSED: Test 1, 8C5DA44C-CDC3-46B3-8619-4E26D34390B7 has associated method \AMW0.WMAA
\AMW0._WDG (2 of 2)
 GUID: 05901221-D566-11D1-B2F0-00A0C9062910
 WMI Object:
   Flags         : 0x00 (None)
   Object ID     : BA
   Instance     : 0x01
60965        Method (WMAA, 3, NotSerialized)
60966        {
60967            CLSB (INFO)
60968            CreateDWordField (INFO, Zero, BUF0)
60969            BUF0 = 0x44534943
60970            If ((Arg1 == One))
60971            {
60972                \_SB.GLED (Arg2, INFO)
60973                If ((BUF0 == 0x44534943))
60974                {
60975                    CLSB (INFO)
60976                    INF0 = 0xE2
60977                }
60978
60979                Local1 = INFO /* \AMW0.INFO */
60980                Return (Local1)
60981            }
60982
60983            If ((Arg1 == 0x02))
60984            {
60985                \_SB.SLED (Arg2, INFO)
60986                If ((BUF0 == 0x44534943))
60987                {
60988                    CLSB (INFO)
60989                    INF0 = 0xE2
60990                }
60991
60992                Local1 = INFO /* \AMW0.INFO */
60993                Return (Local1)
60994            }
60995        }
60996    }
Wanner_G_Intel
Hello dessa, Thank you for joining this Intel Community. The information we have available for WMI for Intel® NUC products is the following: Use WMI Explorer* to Program the Ring LED and Button LED https://www.intel.com/content/www/us/en/support/articles/000023426/mini-pcs/intel-nuc-kits.html The steps described in this article should also work for the units listed under "Related products". We recommend running the latest BIOS updates. In the meantime, we will do further research about this request. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello dessa, I hope you found the information provided on this thread helpful. I am writing to let you know that we also recommend contacting you distro's support websites and forums for more information on WMI Docs or drivers for Linux. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
dessa
Open WannerG_Intel WMI explorer is windows application and doesn't help.
Were you able to confirm that any of NUC8i3BE/NUC8i5BE/NUC8i7BE LED functions work for Windows?
As mentioned above the latest BIOS and Linux was used for test and issue seems to be in firmware.
Wanner_G_Intel
Hello dessa, We are currently doing research to confirm WMI works on these units . As soon as we have any update, we will post it in the following thread: https://forums.intel.com/s/question/0D50P00004DrZVI/nuc-8i5bek-led-software-control?language=en_US&f... Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
