Intel® NUCs
12309 Discussions
Wake On Lan NUC10i7FNHN
pioter-n
I want to enable Wake On Lan function
i am using :
OS : Windows 11 pro x64 Version 22000
My device: Intel NUC10i7FNHN
Network Adapter : Intel(R) Ethernet Connection (10) I219-V 12.18.9.23
I enable wake on
disable fast boot
Using UEFI boot
but when I navigate to the network adapter property in Device Manager->Network adapter> I219, do a right click on then click on the Property. I DO NOT have the Power Management Tab to check if you can find any setting like "Allow this device to wake the computer" or "Only allow a magic packet to wake the computer"
AND I  I DO NOT have it under Advanced tab
LeonWaksman
Hi @pioter-n
Since by default NUC FN sleep mode is set to Modern Standby (rather than Legacy S3 Standby), the  "Allow this device to wake the computer" function is not needed and the Power Tab is missing. The Ethernet  Adapter and/or WiFi Adapter are set to communicate with outside world in Sleep Mode.
Please read more here : Enabling Wake-on-LAN and Overview of Modern Standby user experience for wake
Any way if you want use the Power Tab (which I no suggest to do), you may change the Sleep Mode to Legacy S3 Standby but this should by done only after settings Windows Boot mode to SAFE (otherwise your Windows will be corrupted).
Leon
pioter-n
From my side I had to manually install new driver, but only it works ...  https://www.intel.com/content/www/us/en/download/18293/682170/intel-network-adapter-driver-for-windo...
LeonWaksman
Hi @pioter-n
You need to explain better what you need.  However, this is LAN driver for your NUC: Intel® Network Adapters on the Intel® NUC products using Windows® 10.
Leon
LeonWaksman
Hi @pioter-n
See my solution in the other thread which worked for other user.
Leon
