Community
cancel
Showing results for
Search instead for
Did you mean:
CInfo1
Wake on lan on NUC5PPYH
I can wake up the NUC5PPYH by bios on "wakeup S4/S5", but i can't wake on lan...
I've flashed bios with PY0064.bio and update the drivers on Windows 7 x64.
Is the NUC5PPYH capable WakeOnLan on ethernet ?
- if yes, which parameter to activate ?
Tags (1)
n_scott_pearson
Super User Retired Employee
WOL is definitely supported on the NUC5PPY, NUC5PGY and NUC5CPY platforms.
To enable in BIOS, Deep S4/S5 must be disabled (unchecked) and Wake on LAN from S4/S5 must be set to Power on - Normal Boot.
To enable in Windows, open the Power Management tab in the properties for the Realtek PCIe GBE Family Controller and ensure that Allow this device to wake the computer is enabled (checked).
Hope this helps,
