Intel® NUCs
12315 Discussions
Washed out colors on nuc8i5bek with DVI monitor
darkf3d3
I'm using a nuc8i5bek with a DVI monitor (with a HDMI>DVI cable) and Windows 10.
And recently the monitor started showing washed out colors.
I tested the monitos with other old nuc and the colors are correct, and the same for nuc8i5bek on hdmi monitor.
I found on google this tutorial to fix the problem with using "Intel HD Graphics Control Panel":
https://www.howtogeek.com/285277/how-to-avoid-washed-out-colors-when-using-hdmi-on-your-pc/
The problemit's that I see that it is no more installed on my pc and now there's a new program "Intel Graphics Command Center".
So maybe this is the cause of problem.
I tried also reinstalling old control panel, but the installer says that it is no compatible with my pc.
Do you know how to fix this?
