Community
cancel
Showing results for
Search instead for
Did you mean:
KD3
What PC do you recommend for connecting four D435 cameras?
Jump to solution
What PC do you recommend for connecting four D435 cameras? Does it need to have 4 individual USB 3 host controllers? I'm assuming, yes?
The cameras use USB type - C.
Other criteria would be a small slim PC. What do you recommend?
thanks
Tags (1)
MartyG
The ideal would be to have separate USB controllers, yes.
A starting point for your research into PCs could be the slim Intel NUC 7 mini PC with four USB 3.0 ports. It was released a year ago so is still quite up to date.
https://www.intel.co.uk/content/www/uk/en/products/boards-kits/nuc/mini-pcs/nuc7i7bnkq.html https://www.intel.co.uk/content/www/uk/en/products/boards-kits/nuc/mini-pcs/nuc7i7bnkq.html
A new NUC 8 model is coming this Spring that has 7 USB 3.0 ports, according to the site below.
https://www.intel.com/content/www/us/en/products/docs/boards-kits/nuc/mini-pcs/nuc-8-vr.html The Next VR Machine—Intel® NUC Kit NUC8i7HVK/NUC8i7HNK VR
https://newsroom.intel.com/wp-content/uploads/sites/11/2018/01/intel-nuc-spec-sheet.pdf https://newsroom.intel.com/wp-content/uploads/sites/11/2018/01/intel-nuc-spec-sheet.pdf
MartyG
KD3
Thanks for the suggestion. Do you know if NUC 7 or NUC 8 have dedicated channel controllers for at least 4 of those USB3? I couldnt find that information anywhere. Thanks.
MartyG
I believe the i7bnkq NUC 7 model is covered by this data sheet document:
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i5BN_NUC7i7BN_TechProdSp... https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i5BN_NUC7i7BN_TechProdSp...
I do not have a similar sheet for the forthcoming NUC 8 model. I assume both NUC 7 and NUC 8 have dedicated USB controllers for each USB 3.0 port, but I'll link our resident NUC expert on the forums, N. Scott Pearson - N.Scott.Pearson - into this conversation to get his input, just to be sure.
