Community
cancel
Showing results for
Search instead for
Did you mean:
CBenn5
What are the safe temps for NUC5i7RYH
Ever since Intel sent me a replacement NUC5i7RYH for my original it has been very noisy so bad I could never hear the television surround sound over the NUC5i7RYH. It has been demoted to a cupboard and is still so noisy that it wakes my wife up. Finally on looking in the BIOS I've set it to quiet but it's still noisy. On checking the temps I've found it sometimes hits 97 deg.
Community Manager
Hello Bara-Bus
Thank you for joining the community.
In order to help you better, I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
  1. Run the utility.
  2. Click on "Scan" to get the scanned system.
  3. Once the scan is complete click on "next".
  4. Use the "save" option, save the report to your desktop.
  5. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Leonardo C.
CBenn5
I'm transferring files from 1 device to another :
Look at the temps topping out at 105 degrees.
This can't be right for an i7. It's not doing that amount of work?
intel_corpintel_admin
Community Manager
Hello Bara-Bus
Looking into the information of the processor specifications that unit has; I am noticing that the Tjunction is up to 105°C, comparing this data with the report your unit seems to be working under specs, see the following link for reference.
https://ark.intel.com/products/84993/Intel-Core-i7-5557U-Processor-4M-Cache-up-to-3_40-GHz https://ark.intel.com/products/84993/Intel-Core-i7-5557U-Processor-4M-Cache-up-to-3_40-GHz
Leonardo C.
CBenn5
Thank you for that Leonard. I was getting really concerned because it seems very noisy like a Concorde plane used to be when I lived right under the flight path in London. About 105 decibels. Maybe my hearing has got a little sensitive. I'm getting old now you see. Have a good un. Meaning have a good day!
