Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13496 Discussions
What is the MMIO size in NUC12 extreme
CQCQN
I plan to setup an system with VCA2, but it have minimum requirements for BAR and MMIO.
The VCA user guide said that the host system required:
MMIO mapping above 4 GB is enabled
Minimum MMIO size is 4 GB/CPU (node)
I want to ask, for the 12th generation CPU, is the MMIO size still 4gb? If I need to use VCA2, do I still need to install it on a dedicated server motherboard?
AndrewG_Intel
Hello @CQCQN
We understand that you have some inquiries regarding Intel® NUC 12 Extreme Kits NUC12DCMi[X] with 12th Generation Processors and support of Memory-mapped I/O (MMIO).
Based on the Technical Product Specifications, section 2.4.1 Addressable Memory, page 9; the Intel® NUCs support Memory-mapped I/O that is dynamically allocated for M.2 add-in cards (256 MB).
Also, it is worth keeping in mind that the Intel® NUCs are not intended/recommended to be deployed as a "server".
Regarding your other inquiry about Intel® Visual Compute Accelerator 2 (Intel® VCA 2) "If I need to use VCA2, do I still need to install it on a dedicated server motherboard?", please post this question on the Server Products Forum for proper assistance with inquiries about Intel® VCA 2.
Andrew G.
AndrewG_Intel
Hello CQCQN
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
Alberto_R_Intel
Hello CQCQN, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
