Intel® NUCs
12135 Discussions
What should be the settings when connecting the monitor via hdmi cable? The NUC: auto or 16-235 or 0-255? The monitor: auto or 16-235 or 0-255?
Mike_321
n_scott_pearson
Super User Retired Employee
What parameter(s) are you referring to? I don't recognize these at all.
LeonWaksman
From his previous post I understand that he is using NUC8i3BEH with Benq PD3200Q monitor. I don't understand nether what are the subject parameters.
Leon
Mike_321
RGB range (full - 0:255, limited - 16:235)
LeonWaksman
You probably ask about the Input Range of the colors to be encoded (a setting in a Video part in Intel Graphics Command Center)?
If I'm right , I can say that I'm leaving it is default settings (i.e. Limited)
Leon
Mike_321
Yes. For example, NUC<---HDMI--->Monitor , if I set for NUC = full RGB (range 0:255) and for Monitor = full RGB (range 0:255) then I have a problem with Youtube (not good quality video). I can't understand what's the right settings: NUC(Limited)<---HDMI--->Monitor(Limited) ?
n_scott_pearson
If you change the settings to full range and the output is adversely affected, then, typically, the problem is the HDMI cable being used. I would suggest that you try a better quality cable.
