Is it all in the BIOS, is there an app within Windows? Thanks
You configure the capability through BIOS Setup (Visual BIOS), but an embedded microcontroller (within the Super I/O (SIO) ASIC) actually implements the fan speed control.
Hope this helps,
I would add that you do not want Windows thinking it can control your temps/fans.
Just saying.
Doc
Intel Extreme Tuning Utility may do what you want, but use caution when using it as it directly modifies BIOS entries and its a little wonky...
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- Download Intel® Extreme Tuning Utility (Intel® XTU)
-Robert
Thanks. I'll try that and the BIOS way I've nothing against using the BIOS, it's just I don't like rebooting my machine too often. Got so many scripts and whatever running. Cheers.
Yeah, I loaded up XTU late last night to see if it had any fan control settings and saw that there were none. Bummer...
