Community
cancel
Showing results for
Search instead for
Did you mean:
IPC00
Where are the reset button and the power off button?
Hi, I have a headless NUC7 running Linux. Is there a reset button that I can reboot the machine? Is there a power off button that I can safely shut down the machine?
LeonWaksman
  1. There is no reset button on Intel NUC.
  2. The power button is the same one, you have switched your NUC ON. Can you safely shut down the machine with this button? Depends of your Linux. In Windows 10 you can.
  3. BTW, NUC7 is not the full name of your NUC. You should specify full name.
Leon
IPC00
Thank you Leon.
