Intel® NUCs
12323 Discussions
Which Intel NUC supports a 5k resolution?
CLang25
I would like to buy a NUC which can be used with full resolution via a DP cable to the Samsung c49rg94ssu with 5140x1440 @ 60Hz. I only have one DP port left. Therefore only a DP cable!
Which NUC can do that?
Many thanks for the help.
n_scott_pearson
Super User Retired Employee
A 5K monitor will be 5120x2880. A 5120x1440 monitor is (just) an Ultra-Wide and falls into the 1440p class. Any of the NUCs with USB-C ports will provide a DP 1.2/1.4 channel that can support this resolution. There are also NUCs with DP 1.2/1.4 ports exposed via miniDP connector.
