Intel® NUCs
12336 Discussions
Why Windows 10 Update replacing the Intel Display Driver Version Display - 26.20.100.8141 with version 26.20.100.7529 even after clean installation in Intel NUC8i7BEH.
JLiu13
Is this driver issue and what is the solution?
n_scott_pearson
Super User Retired Employee
This is a known issue (with Windows Update) and is being worked by Intel Customer Support.
One thing you can try is upgrading to the new 8190 build (download form here: https://downloadcenter.intel.com/download/29557/Intel-Graphics-Windows-10-DCH-Drivers).
Hope this helps,
JLiu13
Thank you for the response.
The Windows Version Details as below:
Windows 10 PRO
Version 1909
OS Build 18363.778
Please advise if this issue happens with above build.
I tried to uninstall the driver completely, close the internet connection and installed the graphic driver version 26.20.100.8141.
After one day Windows 10 update automatically updated the graphic driver to version 26.20.100.7529 in my Intel NUC8i7BEH.
I feel the driver version from Windows update has something do with this behavior.
Normally Windows update will not update the newer version of drivers from my past experience.
If you have any information regarding this issue please share the details.
n_scott_pearson
As I said, known issue and they are working on it (amongst a bunch of other, similar issues). You'll have to wait for the next IDSA update.
JLiu13
Thank you for the update.
I will wait for the updates and hopefully this issue will be fixed.
Trial-Member
New Contributor III
I can't confirm that.
I have a NUC8i5BEH with
Windows 10 1909 (Build 18363.815) and
graphics driver 26.20.100.8141
and Windows Update does not try to install an old driver.
Note: About a week ago Intel provided the drivers 27.20.100.8190.
Trial-Member
New Contributor III
JLiu13
Thank you for the update and noted that this issue is not happening with Build 18363.815.
I don't have this build now and may be available soon.
There is optional update KB4550945.
Once I have this build version I can check if this issue occurs.
Currently my OS Build version is 18363.778
JLiu13
Updated to OS Build 18363.836
Noted Windows update replaces the Display Driver Version - 26.20.100.8141 with version 26.20.100.7529
This issue seems something do with driver version 26.20.100.8141 which may be older than version 26.20.100.7529
Appears to be bug in the driver.
Please update me of any information you may have to solve this problem.
n_scott_pearson
The IDSA team is working on this issue. It's affecting a lot more driver types than just graphics. Give them time to fix it right...
JLiu13
Thank you so much for the update. I shall await further updates soon.
Leonardo_C_Intel
Hello JLiu13
Thank you for posting in the Intel Community.
Since the operating system is automatically rolling back the driver I would recommend following the steps on Intel® HD Graphics Installation Error: This Installation Package is Not Supported by this Processor... to try a clean installation of the graphics driver on the system
NOTE: please make sure to follow the steps without an internet connection and follow steps 5 and 6 until the system gets to Microsoft basic display adapter.
Leonardo C.
JLiu13
Dear Leonardo, I thank you for the kind response and your help. I did the procedure as advised by you. However the driver rolls back to the driver as updated by Windows Update. Also suddenly when I tried I tried to log in into my Intel account, I got notified that my password expired. I tried to reset my password. However I get message that I should try later. I am unable to log into my account at Intel. I request your kind help. Kind regards, Santhana
JLiu13
Dear Leonardo,
Kind regards,
Santhana
JLiu13
Finally I opted to reset my password and it worked.
JLiu13
Intel should update the suitable driver for the NUC8i7BEH so that customers not facing this issue.
Worried if the NUC8i7BEH which I have is defective if others don't have this issue.
In this case I need to request the issue under warranty .
Please do advise.
Thank you so much.
n_scott_pearson
When they sort out the cause, it will be taken care of. This issue is affecting a lot more system types than just your BE NUC, so not a system-specific problem you need to worry about.
JLiu13
Thank you so much for the update. I was worried that only my NUC8i7BEH is affected and felt some something wrong with my graphic chip. Now I feel better with your answer and it is very kind of you to advise me of the information.
Leonardo_C_Intel
Hello JLiu13
I would like to confirm if you trying to install the Intel® Graphics - Windows® 10 DCH Drivers for Intel® NUC Version: 26.20.100.8141 by using the steps provided previously.
Please let me know the outcome.
Once you complete the test please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
1-    Run the utility.
2-    Click on “Scan” to get the scanned system.
3-    Once the scan is complete click on “next”.
4-    Use the “save” option, save the report to your desktop.
5-    To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Leonardo C.
JLiu13
Dear Leonardo,
I thank you for the kind response.
As advised by you I made the installation and attaching the LOG file.
After I check Windows update or by tomorrow when Windows update will automatically update this driver with version 26.20.100.7529, I can make the same log and send it to you for evaluation and advise if anything wrong with my NUC.
My NUC was replaced quite some time back due HDD light issue and few other issues.
My NUC details as below:
Regulatory Model: NUC8BEH
Date of Manufacture: 08 September 2019
SKU Number: BOXNUC8i7BEH
Version / SA Number: Private information
ATPO / Serial Number: Private information
Got replacement new NUC on Wednesday, 23 October 2019 at 12:31 PM through DHL delivery.
I await your advice.
I thank you for taking your time to analyse my issue.
Please confirm receipt of my email.
Kind regards,
Santhana
JLiu13
Dear Leonardo,
Kind regards,
Santhana
