Intel® NUCs
12309 Discussions
Why did NUC10 BIOS FN0042.CAP get pulled?
luckman212
On 6/15/2020 BIOS 0042 for NUC10 (FN) series was published at https://downloadcenter.intel.com/download/29631/BIOS-Update-FNCML357-?product=188811
Now it's gone, been pulled and we are back at 0041
What was the reason? I flashed 0042 on 4 systems already, just want to know if it's buggy, dangerous etc.
svenry
I guess due some Troubles.
i am on it since two days and experiencing no issues.
seems a new Version is the way
svenry
in the meantime Version 42 and 41 are withdrawn on current Version is 39.
To avoid isues i did an recovery to Version 39.
sbmi
I have 1 system on 0039, one on 0041, and one on 0043.
I guess I'll be saving every BIOS version and release notes PDF I see from now on.  I wish Intel would tell us what's going on.
n_scott_pearson
Super User Retired Employee
Intel historically does not provide these kinds of updates. I don't expect them to change their policies now.
If a BIOS is withdrawn, it is because it causes errant operation (including potentially bricking systems) or has a security issue.
If a BIOS is withdrawn, it is recommended that you attempt to use the BIOS Recovery process to downgrade to the last supported BIOS version.
svenry
i chatted with an support agent and he recommended to recover to version 39.
however the agent doesnt sound like an human and did not answer my question, just this recommendation.
anway, if there would be an big trouble with the withdrawn version, i guess intel would have noted or communicated somehow.
n_scott_pearson
LOL! No, there's no automated response capability; that was a real person. I sure wish they would do more than provide boilerplate responses.
Sadly, no, they do not provide notifications for withdrawn BIOS releases. The support engineers may end up talking about them, but they don't have a place to put notices of this type. Wish they would, however.
Edit: Here's an example: Suppose there was a security issue in a BIOS. Standard policy in most companies is that you do not talk about security issues until a solution is available. In this case, they would pull the BIOS and then nothing would be said until the replacement BIOS was available. This example I accept; that's policy in many companies. The case that I (and obviously you) find problematic are the ones where the BIOS is bricking folks and nothing gets said.
sbmi
And standard policy is to not inform customers that they BIOS versions they've downloaded over the last 4 months are unstable / insecure?
There's no excuse for this.
tstob1
it works okay with bios 42, would be nice to see something new soon.
luckman212
Any update on this? 42 and 41 still gone, we are at 39 again
Is there a newer / safe version that can be downloaded?
Thank you
sbmi
I have a support case open with Intel, and they told me this:
FNCML357.0042, FNCML357.0041
Reason for removal
The BIOS changes the SATA Mode Selection to AHCI when it should be set to: Intel® RST Premium with Intel Optane System Acceleration or RAID. This causes the Intel® NUC not to boot.
I have no idea if that's the only reason for removal.  I have no idea why they don't make this info public.
luckman212
@sbmi Thank you for that info.  Yes I agree some public info on why these are removed would be very helpful (please INTEL !!) otherwise we are left worrying that maybe a flashed BIOS got pulled for something more serious, some crashing/memory corruption/etc ...
GProc3
I believe this happened to me too, with no way to get back to Optane.
Anonymous
Not applicable
 Intel released FN0043.CAP.
tstob1
shows BIOS 43, then on the download page, it's 39??
luckman212
Could be a caching issue? I got 43 when I downloaded it this morning
SHA256 hash is 2163557940e6a55b9909e89218144561a7870105b12edb32edac668ab8f1f5eb
RJamm
Have they pulled it again?
I am on 0042 after 0041 on my NUC10i5, and both had problems with restarting after BIOS updates. They "forgot" several settings and devices were disabled and such things.
Edit to clarify: since I restored my settings, everything is going fine with 0042.
sbmi2
I can't find 0043, so it looks like it was pulled again.
FYI my sbmi account appears to be banned without any sort of cause, warning, or notification.  All but 1 of my posts (the one in this thread) were deleted, including posts that others had replied to.
svenry
indeed.
i catched it yesterday and works great, no issues.
makes no good impression.
sbmi
Take a look at https://downloadcenter.intel.com/download/29717/BIOS-Update-FNCML357-?product=188811
Intel has now posted at least a general notice that the newer BIOS versions have been pulled.  This is a step in the right direction.
RJamm
Now BIOS 0044 is out. Of course I've had to do the full setup again, but it works so far.
