Intel® NUCs
12146 Discussions
Why does my Intel NUC iwlwifi module crash on CentOS 7?
CCraw4
Experts,
I am not a Linux admin and I am pulling my hair out trying to figure out why the WiFi on my Intel NUC with CentOS 7 continues to die. I saw the similar post already, however, that user was using Ubuntu and the path you all were going down there did not help me.
As info, I have 5 node Hadoop cluster and they are all configured the same (as far as I can tell), however, the other machines which are on WiFi do not crash. I don't know what is wrong with this particular machine.
Here is the error from /var/log/messages. It is the same message that I see regularly as I've been watching this problem for days.
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: Microcode SW error detected. Restarting 0x2000000.
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: Start IWL Error Log Dump:
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: Status: 0x00000100, count: 6
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: Loaded firmware version: 34.0.1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x000022CE | ADVANCED_SYSASSERT
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x05900280 | trm_hw_status0
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | trm_hw_status1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00023FDC | branchlink2
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x0003915A | interruptlink1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | interruptlink2
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x0000012C | data1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x03830000 | data2
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xDEADBEEF | data3
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xD28011F1 | beacon time
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x72F4FDDD | tsf low
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000182 | tsf hi
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | time gp1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xCA511FA7 | time gp2
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000001 | uCode revision type
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000022 | uCode version major
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | uCode version minor
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000230 | hw version
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00C89000 | board version
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x0A96001C | hcmd
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xA7F93882 | isr0
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00050000 | isr1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x0020180A | isr2
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x40417DCD | isr3
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | isr4
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x0A95001C | last cmd Id
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | wait_event
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00004288 | l2p_control
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00018024 | l2p_duration
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | l2p_mhvalid
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x000000EF | l2p_addr_match
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x0000000D | lmpm_pmg_sel
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x30101345 | timestamp
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00007888 | flow_handler
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: Status: 0x00000100, count: 7
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000070 | ADVANCED_SYSASSERT
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | umac branchlink1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xC0086964 | umac branchlink2
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xC0083A94 | umac interruptlink1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xC0083A94 | umac interruptlink2
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000800 | umac data1
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xC0083A94 | umac data2
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xDEADBEEF | umac data3
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000022 | umac major
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | umac minor
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xC088628C | frame pointer
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0xC088628C | stack pointer
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00DF019C | last host cmd
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: 0x00000000 | isr status reg
Jan 2 08:41:06 mapr04 kernel: ieee80211 phy0: Hardware restart was requested
Jan 2 08:41:06 mapr04 kernel: iwlwifi 0000:3a:00.0: FW error in SYNC CMD STATISTICS_CMD
Jan 2 08:41:06 mapr04 kernel: CPU: 0 PID: 4898 Comm: NetworkManager Kdump: loaded Not tainted 3.10.0-957.1.3.el7.x86_64 #1
Jan 2 08:41:06 mapr04 kernel: Hardware name: Intel Corporation NUC7i7BNH/NUC7i7BNB, BIOS BNKBL357.86A.0049.2017.0724.1541 07/24/2017
Jan 2 08:41:06 mapr04 kernel: Call Trace:
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaeb61e41>] dump_stack+0x19/0x1b
Jan 2 08:41:06 mapr04 kernel: [<ffffffffc0afa983>] iwl_trans_pcie_send_hcmd+0x563/0x580 [iwlwifi]
Jan 2 08:41:06 mapr04 kernel: [<ffffffffae4c2d00>] ? wake_up_atomic_t+0x30/0x30
Jan 2 08:41:06 mapr04 kernel: [<ffffffffc0b060fc>] iwl_trans_send_cmd+0x5c/0xe0 [iwlwifi]
Jan 2 08:41:06 mapr04 kernel: [<ffffffffc0c6d312>] iwl_mvm_send_cmd+0x32/0xb0 [iwlmvm]
Jan 2 08:41:06 mapr04 kernel: [<ffffffffc0c6e632>] iwl_mvm_request_statistics+0x72/0x100 [iwlmvm]
Jan 2 08:41:06 mapr04 kernel: [<ffffffffc0c616fe>] iwl_mvm_mac_sta_statistics+0xbe/0x100 [iwlmvm]
Jan 2 08:41:06 mapr04 kernel: [<ffffffffc0bb68f7>] sta_set_sinfo+0xb7/0x800 [mac80211]
Jan 2 08:41:06 mapr04 kernel: [<ffffffffc0bcd052>] ieee80211_get_station+0x52/0x80 [mac80211]
Jan 2 08:41:06 mapr04 kernel: [<ffffffffc08cae41>] nl80211_get_station+0xa1/0x240 [cfg80211]
Jan 2 08:41:06 mapr04 kernel: [<ffffffffae794d0d>] ? list_del+0xd/0x30
Jan 2 08:41:06 mapr04 kernel: [<ffffffffae5bdf1a>] ? __rmqueue+0x8a/0x460
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea77918>] genl_family_rcv_msg+0x208/0x430
Jan 2 08:41:06 mapr04 kernel: [<ffffffffae5bf134>] ? free_one_page+0x2e4/0x310
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea77b9b>] genl_rcv_msg+0x5b/0xc0
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea73ec0>] ? __netlink_lookup+0xc0/0x110
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea77b40>] ? genl_family_rcv_msg+0x430/0x430
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea75bab>] netlink_rcv_skb+0xab/0xc0
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea760e8>] genl_rcv+0x28/0x40
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea75530>] netlink_unicast+0x170/0x210
Jan 2 08:41:06 mapr04 kernel: [<ffffffffae78c042>] ? memcpy_fromiovec+0x62/0xb0
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea758d8>] netlink_sendmsg+0x308/0x420
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea73112>] ? netlink_recvmsg+0x212/0x490
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea193a6>] sock_sendmsg+0xb6/0xf0
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea194f5>] ? sock_recvmsg+0xc5/0x100
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea1a269>] ___sys_sendmsg+0x3e9/0x400
Jan 2 08:41:06 mapr04 kernel: [<ffffffffae656fe0>] ? __pollwait+0xf0/0xf0
Jan 2 08:41:06 mapr04 kernel: [<ffffffffae68ee1e>] ? ep_poll+0x31e/0x360
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea1b921>] __sys_sendmsg+0x51/0x90
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaea1b972>] SyS_sendmsg+0x12/0x20
Jan 2 08:41:06 mapr04 kernel: [<ffffffffaeb74ddb>] system_call_fastpath+0x22/0x27
Where should I start trying to debug?
Here are some things which I think might be helpful:
uname -a:
Linux mapr04.wired.carnoustie 3.10.0-957.1.3.el7.x86_64 #1 SMP Thu Nov 29 14:49:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
dmesg | grep iwlwifi:
[ 3.822041] iwlwifi 0000:3a:00.0: irq 132 for MSI/MSI-X
[ 3.831295] iwlwifi 0000:3a:00.0: loaded firmware version 34.0.1 op_mode iwlmvm
[ 3.924043] iwlwifi 0000:3a:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 3.984049] iwlwifi 0000:3a:00.0: base HW address: f8:94:c2:5c:07:24
Wanner_G_Intel
Hello CCraw4, Even though Intel NUC users have reported Linux versions as compatible, Intel has not validated this operating system on Intel® NUC products. We recommend you use the latest kernel and contact your Linux vendor and use their distribution resources for driver downloads and support. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Vladimir_S
Hi CCraw4,
From your system information, it is clear that your kernel version is 3.10.0 (custom compiled?)​, and your wireless adapter is Intel AC 8265, so we have to visit the following page https://www.intel.com.au/content/www/au/en/support/articles/000005511/network-and-i-o/wireless-netwo... to check how it is compatible with system requirements. In result, the page states that to support your wireless adapter it requires a kernel version 4.6 or higher!
Best regards, Vladimir.S​
