I have 2 intel nuc, one model NUC7i7BNH and the other one is NUC7i5BNH. I also have 2 NVMe M.2 sdd loaded with the same image, the 2 ssd fix perfect on the NUC7i7BNH model, but when I try to fix the other NUC model it doesn't work with any of the 2 ssd, it sends me the following error:
"Restart and select the appropriate boot device or insert the boot media into the selected boot device and press a key"
Which I do not understand since the 2 ssd work perfectly in the NUC7i7BNH. What could be the problem?
Regards.
