It is a pity that the NUC X15 does not have a dGPU direct connection, but as a studio laptop, why not design an iGPU Only mode for low-performance, low-power scenarios such as office and entertainment?
The dGPU can be disabled by setting relevant options in the BIOS or the Intel®NUC Software Studio and using only the Integrated graphics. In this way, resources can be saved more effectively in daily use. When the dGPU needs to work, it can be switched with a button and restart.
Hello @Joker5017
We understand that you have some feedback/suggestions regarding the Intel® NUC X15 Laptop Kits and the possibility for "integrated GPU only" variants and/or options to disable the discrete GPU.
We will document this feedback and route it to the appropriate team. Unfortunately, the team will not be able to provide you with updates regarding the status of the suggestion/request and we cannot promise that this will be implemented.
However, we do appreciate your feedback and interest in Intel® Products.
Andrew G.
Hello @Joker5017
Andrew G.
