Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Will I void my warranty if I remove (and reinstall) the NUC motherboard from the chassis?
Jump to solution
Hi!
I need to unplug the CMOS battery (NUC6i3SYH) and the only way to reach it is to remove the motherboard.
Will this void the warranty?
Accepted Solutions
Highlighted
Super User Retired Employee
No, it won't - unless you damage the board or chassis in the process. Be very careful!
Highlighted
Highlighted
Thanks for the answer, I will be careful!
