Community
cancel
Showing results for
Search instead for
Did you mean:
spuff
New Contributor II
Will Intel Optane SSD 800p work in NUC Kit NUC6i5SYK?
I have a Samsung 960 EVO installed in subject kit. The Optane has a PCIe 3.0 X2, NVMe interface but the pin profile is different from the Samsung SSD.
Community Manager
Hello provo44,
Thank you for contacting us regarding the compatibility questions that you have between our Intel ® NUC Kit NUC6i5SYK and our Intel® Optane™ SSD 800P Series; I will be more than a pleasure to provide you with all the details about it.
In this case here you will find the lists of compatible NUC kits:
https://www.intel.com/content/www/us/en/support/articles/000024061/mini-pcs/intel-nuc-kits.html https://www.intel.com/content/www/us/en/support/articles/000024061/mini-pcs/intel-nuc-kits.html
You need:
-One of the supported Intel NUC models from the table above (7th generation CPU or above)
-Intel Optane Memory (m.2 format)
-2.5-inch (6.35cm) SSD or HDD SATA drive
-Windows® 10, 64-bit* operating system
-Intel® Optane™ technology software
I regret to inform you that in this case the device that you own does not meet the requirements in order to work with our Intel® Optane™ SSD 800P Series due to the fact that the NUC Kit NUC6i5SYK comes with a 6th Generation Intel® Core™ Processor, my most sincere apologies for the inconvenience that this may cause.
I hope this helps,
Diego S.
spuff
New Contributor II
Thanks. Will wait for Cannon Lake.
