Community
cancel
Showing results for
Search instead for
Did you mean:
JVive
Will NUC7i5BNK work with only 1 RAM stick of 8 GB? In that case, in wich slot should I put it?
Jump to solution
I've recently bought an Intel NUC7i5BNK and I'm about to set it up but I dont know if it will work with only one 8GB RAM stick. Will it?
The RAM I've bought is the following:
HyperX Impact 8GB DDR4 2400MHz 8GB
In case that this configuration is possible, in which slot should I put the only RAM stick I have?
Jordi
Tags (1)
LeonWaksman
You didn't mention the P/N of your module and I presume that this is HX424S14IB2/8. If I'm right it should work, although it is not listed on the tested by Intel memory: http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...
2400 MHz memory modules will work on these Intel NUCs, but because the processor only supports speeds up to 2133 MHz, higher-speed SO-DIMMs operate only at the 2133 MHz memory timing.
If you plan to install just one SO-DIMM, install it in the lower memory socket.
Hope this helps
Leon
LeonWaksman
Hope this helps
Leon
JVive
In effect, it is HX424S14IB2/8.
Thank you for your quick response!
Jordi
