I have two Intel NUCs, one of which has a brand new install of Windows 10. Both computers suffer from the same problem. As they start to go through the sleep process after the prescribed inactive time, they turn back on. I've isolated this to the USB port on the HP e320t monitor. This is a touch screen monitor, if that matters.
I have the most recent drivers from both Intel and HP. I am wondering if anyone has suggestions on what might be going wrong.
Hello HanMan
In order to review this further, could you please provide us with the following information?
1- Are the Intel® NUCs new devices? Do they have the exact same configuration? (Operating system version, RAM, and SSD models, are both connected to an HP* E320t Touch Monitor? same type and brand of cable? etc...)
2- Did this configuration (Intel NUC + HP* monitor) work fine before? If yes, were any recent hardware or software changes that might relate to the point when the behavior started?
3- When you said you have "isolated this to the USB port on the HP* monitor", do you mean the USB upstream connector and the USB HUB? Please provide details regarding how you determined this.
4- What type of devices or peripherals do you have connected to the USB HUB ports on the monitor? Also, if you disconnect the NUC from the USB upstream on the monitor and connect the peripheral/devices directly to the Intel® NUC's USB ports (without any other USB HUB), does the behavior persist?
5- What type of video cables and video ports are you using to connect the Intel® NUC and the monitor? Are you using a straight-through connection with a single cable? Or are you using any type of video adapters, converters, or dockings? Please provide details.
6- For both Intel® NUCs, please run the Intel® System Support Utility (Intel® SSU) to gather more details about the systems:
- Download the Intel® SSU and save the application on your computer
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
- Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
Recently I decided to delve into this problem, so I took my decommissioned i7 NUC and installed a fresh Windows 10 OS onto it, loaded the Intel drivers, and then tested the sleep. I should have done this before I loaded the Intel drivers, but unfortunately I did not. I can confirm that even after these few steps, I was unable to get the system to go to sleep on its own. I can manually "sleep" it, but it will not do so automatically.
Behavior wise, this is what happens....
If I set a fast sleep timeout (say 1 minute) on Windows, after the prescribed time, the screen goes blank. It looks as though the whole thing is going to sleep, which is great. However, after 15 seconds or so (I can get more accurate time, if this is important), the screen turns back on. This cycle will continue to repeat itself forever, as best as I can tell.
Also consistent with the removal of the cable test, if I go into the Device Manager and disable the 'Generic USB Hub', the sleep works fine too. However, this once again prevents me from using either the monitor USB hub or the touch screen built into the monitor.
Hello HanMan
Thank you for your response and for all these details.
We would like to inform you that due to the Intel® NUC Kit NUC5i5RYH has been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help with this product. You may also find the Discontinued Products website helpful to address your request.
Having said that, we will focus on the issue with the Intel® NUC Kit NUC6i7KYK. Thank you for your understanding.
As per the HP* monitor's User Guide, if the monitor's power saving control is disabled, it may cause issues with sleep mode. Could you please verify if this feature is enabled? Open the OSD menu and select Power Control > Auto-Sleep Mode and set auto-sleep to On.
Also, it seems with are missing the Intel® SSU report. Please kindly provide us with a report from the Intel® NUC Kit NUC6i7KYK following these steps:
Andrew G.
Hello HanMan
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Andrew G.
Hi Andrew,
Sorry about the delay. I had some thing come up and then after I ran the report, I wanted to review the information before posting. I'm a bit on the 'secure' side of things so I wanted to check it for PII. There were a few things that I redacted, but otherwise it is fine and posted below. Everyone seems to remove serial numbers on forums which is a little curious to me, but I figured I might as well follow suite.
I also wanted to take the time to check the manual you referenced in a previous post. My monitor has "Auto Sleep" set to ON. In addition, "Power On Recall" is set to ON, and the Sleep Timer is setup to shut the monitor off at midnight. It should be noted, that once the monitor performs this action, then the NUC *will* go to sleep and remain so. However, this eliminates my use of the USB port as a 'wake' device as the monitor is truly OFF until I press the ON button. It is a bit of an odd use case. I could live with that, but I really would prefer my machine go to 'sleep' automatically after the Windows configured timeout period, not as a function of the monitor setting (whose granularity is a bit like doing surgery with a sledge hammer).
Here is the service dump (again, minor redactions, essentially removing all serial numbers and Network SID info):
# SSU Scan Information
Scan Info:
Version:"2.5.0.15"
Date:"09/29/2021"
Time:"00:00:12.6000954"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Intel Corporation"
BIOS Mode:"Legacy"
BIOS Version/Date:"American Megatrends Inc. KYSKLi70.86A.0041.2016.0817.1130 , 08/17/2016 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz , GenuineIntel"
Secure Boot State:"Not Available"
SMBIOS Version:"3.0"
Sound Card:"Intel(R) Display Audio"
Sound Card:"High Definition Audio Device"
System Manufacturer:"Not Available"
System Model:"Not Available"
System SKU:"Not Available"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Iris(R) Pro Graphics 580"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Iris(R) Pro Graphics 580"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Pro+Graphics+580"
CoInstallers:"oem2.inf,iSKLD_w10_DS,Internal,Intel(R) Iris(R) Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"04/10/2020 05:00 PM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_937fd4310898f7d8\igdkmd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"26.20.100.8141"
INF:"oem2.inf"
INF Section:"iSKLD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_937fd4310898f7d8\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_937fd4310898f7d8\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_937fd4310898f7d8\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_937fd4310898f7d8\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_193B&SUBSYS_20648086&REV_09\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"50 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Iris(R) Graphics Family"
- "Memory"
Physical Memory (Available):"28.04 GB"
Physical Memory (Installed):"32 GB"
Physical Memory (Total):"31.89 GB"
- "BANK 0"
Capacity:"16 GB"
Channel:"ChannelA-DIMM0"
Configured Clock Speed:"2400 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"First position"
Manufacturer:"1315"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"CT16G4SFD824A.C16FHD"
Serial Number:""
Status:"Not Available"
Type:"Synchronous"
- "BANK 2"
Capacity:"16 GB"
Channel:"ChannelB-DIMM0"
Interleave Position:"Second position"
Manufacturer:"1315"
Serial Number:""
Type:"Synchronous"
- "Motherboard"
BIOS:"BIOS Date: 08/17/16 11:30:55 Ver: 05.0000B, INTEL - 1072009"
Caption:"Motherboard"
- "Chipset":"Intel(R) 100 Series/C230 Series"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=100+Series%2fC230+Series"
Date:"08/16/2016 05:00 PM"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"NUC6i7KYB"
Serial Number:""
Status:"OK"
Version:"H90766-406"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 AM"
Driver Path:"C:\Windows\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.19041.1"
Index:"0013"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"09/21/2021 07:38 PM"
MAC Address:"A0:C5:89:99:48:8B"
Manufacturer:"Microsoft"
Media Type:
Net Connection ID:"Bluetooth Network Connection"
NetCfgInstanceId:"{2E3977D9-0CC5-4209-9C4E-CFBFDA2405B8}"
Number of VLANs:"0"
PNP Device ID:"BTH\MS_BTHPAN\6&1B357DA7&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Team Name:"Not in a team"
Temperature:
Type:"Ethernet 802.3"
- "Service Bindings"
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
- "Intel(R) Dual Band Wireless-AC 8260"
Access Point:"a0:04:60:16:e8:d4"
Authentication:"WPA2-Personal"
- "Caption":"Intel(R) Dual Band Wireless-AC 8260"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Dual+Band+Wireless+AC+8260"
Channel:"48"
Cipher:"CCMP"
Connection Mode:"Auto Connect"
Default IP Gateway:"192.168.1.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"09/24/2021 01:28 PM"
DHCP Lease Obtained:"09/23/2021 01:28 PM"
DHCP Server:"192.168.1.1"
Driver:"Netwtw06.sys"
Driver Date:"06/22/2021 12:00 AM"
Driver Path:"C:\Windows\system32\drivers\Netwtw06.sys"
Driver Provider:"Intel"
Driver Version:"20.70.25.2"
Index:"0002"
INF:"oem26.inf"
INF Section:"Install_MPCIEX_GENSDNBT1_8260_AC_2x2_HMC_WINT_64_AC"
Installed:"Yes"
IP Address:"192.168.1.112;fe80::9152:99be:2e17:759"
IP Subnet:"255.255.255.0;64"
MAC Address:"A0:C5:89:99:48:87"
Media Type:
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{8F101604-5ED5-485D-AB66-9E00E6AFB5AE}"
Network Name:"Network_LAN"
Network Type:"Infrastructure"
Number of VLANs:"0"
PNP Device ID:"PCI\VEN_8086&DEV_24F3&SUBSYS_90108086&REV_3A\4&BD9248E&0&00E2"
Product Type:"Intel(R) Dual Band Wireless-AC 8260"
Profile:"Network_LAN"
Radio Type:"802.11ac"
Receive Rate:"650 Mbps"
Service Name:"Netwtw06"
Signal Strength:"87%"
State:"connected"
Status:"Enabled"
Temperature:
Transmit Rate:"650 Mbps"
QoS Packet Scheduler:
- "Settings"
*DeviceSleepOnDisconnect:Sleep on WoWLAN Disconnect:"Disabled (0)"
*PacketCoalescing:Packet Coalescing:"Enabled (1)"
*PMARPOffload:ARP offload for WoWLAN:"Enabled (1)"
*PMNSOffload:NS offload for WoWLAN:"Enabled (1)"
*PMWiFiRekeyOffload:GTK rekeying for WoWLAN:"Enabled (1)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on Pattern Match:"Enabled (1)"
ChannelWidth24:Channel Width for 2.4GHz:"Auto (1)"
ChannelWidth52:Channel Width for 5GHz:"Auto (1)"
CtsToItself:Mixed Mode Protection:"RTS/CTS Enabled (0)"
FatChannelIntolerant:Fat Channel Intolerant:"Disabled (0)"
IbssTxPower:Transmit Power:"5. Highest (100)"
IEEE11nMode:802.11n/ac Wireless Mode:"802.11ac (2)"
MIMOPowerSaveMode:MIMO Power Save Mode:"Auto SMPS (0)"
RoamAggressiveness:Roaming Aggressiveness:"3. Medium (2)"
RoamingPreferredBandType:Preferred Band:"1. No Preference (0)"
ThroughputBoosterEnabled:Throughput Booster:"Disabled (0)"
uAPSDSupport:U-APSD support:"Disabled (0)"
WirelessMode:802.11a/b/g Wireless Mode:"6. Dual Band 802.11a/b/g (34)"
- "Intel(R) Ethernet Connection (2) I219-LM"
- "Caption":"Intel(R) Ethernet Connection (2) I219-LM"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Ethernet+Connection+(2)+I219+LM"
DHCP Enabled:"Yes"
Driver:"e1d68x64.sys"
Driver Date:"09/29/2020 12:00 AM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\e1d68x64.inf_amd64_26255692c8b1c6b6\e1d68x64.sys"
Driver Version:"12.19.0.16"
ETrackID:"Not Available"
Index:"0001"
INF:"oem16.inf"
INF Section:"E15B7.10.0.1.19H1"
Installed:"Yes"
MAC Address:"00:1F:C6:9C:B0:AB"
Manufacturer:"Intel"
Media Type:
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{8E4CA684-ADA2-4754-95CF-AE26174F438B}"
Number of VLANs:"0"
NVM Version:"Not Available"
Part Number:"FFFFFF-0FF"
PNP Device ID:"PCI\VEN_8086&DEV_15B7&SUBSYS_20648086&REV_31\3&11583659&0&FE"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Ethernet Connection (2) I219-LM"
Service Name:"e1dexpress"
Status:"Enabled"
Temperature:
- "Settings"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*JumboPacket:Jumbo Packet:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload V2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload V2 (IPv6):"Enabled (1)"
*NumRssQueues:Maximum Number of RSS Queues:"2 Queues (2)"
*PMARPOffload:Protocol ARP Offload:"Enabled (1)"
*PMNSOffload:Protocol NS Offload:"Enabled (1)"
*PriorityVLANTag:Packet Priority & VLAN:"Packet Priority & VLAN Enabled (3)"
*PtpHardwareTimestamp:PTP Hardware Timestamp:"Disabled (0)"
*ReceiveBuffers:Receive Buffers:"256 (256)"
*RSS:Receive Side Scaling:"Enabled (1)"
*RSSProfile:RSS load balancing profile:"ClosestProcessor (1)"
*SoftwareTimestamp:Software Timestamp:"Disabled (0)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*TransmitBuffers:Transmit Buffers:"512 (512)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
AdaptiveIFS:Adaptive Inter-Frame Spacing:"Disabled (0)"
AutoPowerSaveModeEnabled:Link Speed Battery Saver:"Disabled (0)"
EEELinkAdvertisement:Energy Efficient Ethernet:"On (1)"
EnablePME:Enable PME:"Enabled (1)"
ITR:Interrupt Moderation Rate:"Adaptive (65535)"
LinkNegotiationProcess:Legacy Switch Compatibility Mode:"Disabled (1)"
LogLinkStateEvent:Log Link State Event:"Enabled (51)"
MasterSlave:Gigabit Master Slave Mode:"Auto Detect (0)"
ReduceSpeedOnPowerDown:Reduce Speed On Power Down:"Enabled (1)"
SipsEnabled:System Idle Power Saver:"Disabled (0)"
ULPMode:Ultra Low Power Mode:"Enabled (1)"
WaitAutoNegComplete:Wait for Link:"Auto Detect (2)"
WakeOnLink:Wake on Link Settings:"Disabled (0)"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Locale:"United States"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 10 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"5.00 GB"
Physical Memory (Available):"28.05 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.19043 Build 19043"
Virtual Memory (Available):"32.91 GB"
Virtual Memory (Total):"36.89 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [9/17/2021]"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [9/17/2021]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [9/17/2021]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [9/17/2021]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB5000736:"Update [4/9/2021]"
KB5004331:"Update [9/18/2021]"
KB5005565:"Security Update [9/18/2021]"
KB5005699:"Security Update [9/18/2021]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [9/17/2021]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [9/17/2021]"
SP1:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [Not Available]"
SP1:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [Not Available]"
- "Processor"
- "Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 94 Stepping 3"
- "Chipset Name":"Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+i7+6770HQ+CPU+"
CPU Speed:"2.59 GHz"
Current Voltage:"9. volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 AM"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Version:"10.0.19041.546"
Ext. Family:"Not Available"
Family:"Intel Core™ i7-2760QM"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"4 x 128 KB"
Level 2 Cache:"4 x 1024 KB"
Level 3 Cache:"6 MB"
Load:"4%"
Manufacturer:"GenuineIntel"
Model:"94"
Name:"Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz"
Number of Cores:"4"
Number of Cores Enabled:"4"
Number of Logical Processors:"8"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF000506E3"
Revision:"24067"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"3"
- "Storage"
- "WDBRPG5000ANC-WRSN"
Capablities:"Random Access, Supports Writing"
Caption:"WDBRPG5000ANC-WRSN"
Cylinder - Total:"60801"
Description:"Disk drive"
Driver Version:"10.0.19041.789"
Error Code:"Device is working properly"
Firmware Revision:"111130WD"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(Standard disk drives)"
Model:"WDBRPG5000ANC-WRSN"
Partitions:"3"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_WDBRPG5000ANC-WR\5&3A60CEA1&0&000000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"0"
Sectors - Per Track:"63"
Sectors - Total:"976768065"
Serial Number:""
Size – Available:"405.18 GB"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"15504255"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Name:"Not Available"
Serial Number:""
Volume Dirty:"No"
...#SSU#...
Hello HanMan
We have not heard back from you so we will proceed to close this thread now. Since you mentioned that sleep works fine when removing the USB cable or when disable the 'Generic USB Hub' on Device Manager, chances are this issue is triggered by the monitor. In this case, we recommend checking this further with the monitor manufacturer for further assistance and debugging. For your convenience, here is the link to HP* Support.
Andrew G.
Hi Andrew,
I am sorry... I thought I uploaded the file, but I guess it didn't go through. I'll try again... I've run the report but removed the PII serial numbers because that seems to be a pretty standard practice now. Ditto with the SID.
I can tell you that Auto-Sleep is set to ON. In addition, Power-On Recall is set to ON. I have a sleep timer setup for midnight and when the monitor goes to sleep, *generally* the NUC will as well. But that is a pretty brute force way of trying to get the system to sleep. I've also noticed that if I have anything plugged into the monitor USB (such as a Windows Hello webcam) I *think* that this may even prevent the sleep to occur when the monitor is supposed to power down (not sure about that one). Anyhow, here is my system report:
