Intel® NUCs
Assistance in Intel® NUC products
12944 Discussions
Windows 10 HDR Switch
DDewg
Does anyone know if there is software, or a command line switch to enable and disable HDR in Windows 10?
Power DVD can do it, so there must be a programmatic way... I'm looking for a quick way to enable HDR before watching Netflix or Hulu, then a quick way to disable it when I'm done.
I know it's easy to go into display properties, turn it on, click Keep Settings, then close the window. Could be much faster with a single click. :-)
Hello Dewg,
I understand that you are looking for a "shortcut" in order to enable/disable the HDR from Windows*.
Regarding this, I was doing some research but I was unable to find a way to do so, since this feature is provided by the Operating System I would strongly suggest that you contact them either via their forums/support site or by phone and check with them to see if that option exists.
I apologize for any inconvenience.
David V
Hello Dewg,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
