Community
cancel
Showing results for
Search instead for
Did you mean:
JOsbo4
Windows 7 on NUC5CPYH, USB2 ports not working
I'm trying to install Windows 7 on NUC5CPYH. This NUC has USB2 ports (internal) - I connected my keyboard and mouse to these ports. They work in bios, however they stop working during Windows 7 installation.
I know about "Windows 7 USB 3.0 Creator Utility", but it's only required for "NUC products that have only USB 3.0 ports". I don't have second computer, so I'm unable to use this utility.
Is where any other way I can install Windows 7? Why USB2 ports stop working?
n_scott_pearson
Super User Retired Employee
Actually, while the internal ports are USB2, they are connected through an internal USB3 hub and thus you need the USB3 drivers installed into your boot image in order to complete the install. Bottom line, you will need to find another PC on which to run the Windows 7 USB 3.0 Creator Utility and update an installation image.
Sorry,
Community Manager
Hello Joe15,
This is to do a follow up on your post and find out if you had further questions related to this matter.
Esteban C
