For the current plan I only have local infrastructure in deployment depth planned. Quite honestly if I set up my ASDS services it returns with GoDaddy server authentication automatically. Which is weird in my home. I don't want that. The question is simpler I think. Do I install the ISDA? Intel Support and Driver Assistant. I like to write that in full from now on.
Hello lEdge
Thank you for posting on the Intel️® communities. We are working on this request, the updates will be posted on the thread.
David G
After reviewing our available resources, neither the NUC nor the DSA support this version of Windows. We recommend that you use one of the supported operating systems port el NUC:
- Supported Operating Systems for Intel® NUC Products
- https://www.intel.com/content/www/us/en/support/articles/000005628/intel-nuc.html
And here you can see what operating systems you can use with the Intel DSA:
David G
I know that. But, Intel did make Updates for linked hardware. That's why I ask.
Too be honest. It's kind of late. And it's also too late for a decisive answer. I recognize the problem myself. I have to wait for an opportunity to get a new hard disk. So that I don't have to make any backups. I figured it would be easier. Because I now have to replace it with Windows Server 2022 Datacenter. And, I was actually supposed to make that drive a 2012. That's why I asked. It was a mistake on my part.
And still that question is alive since aforementioned updates.
Intel® Chipset Device Software for NUC6i7KYK
Thunderbolt™ 3 Driver for Windows® Server 2016* for NUC6i7KYK, NUC8i7HNK, NUC8i7HVK
It's just that I only find the 2 above.
I can make this one USB Bootable. So it's not like it's going away.
Well. That one is actually doing just that. It's for the laptop. I'm taking the steps necessary one at a time. That's all folks.
R2
Well, okay. Several things to consider. The Windows Server 2022 Datacenter does accept Intel DSA. It just doesn't seem to have any use for now. And it would be obvious that 2022 release is just for the service pack update. There isn't much change just mostly fixes of the 2016 server. And whoo-hoo. Finally just a click away from the remote desktop settings. It works great. I can finally work mostly from the office room.
I may check if I can find the regular drivers. Although the Operating System already installed a chipset drive. I think that's what asked for a restart after installation. I did get a new hard disk because I decided not to waste time backing anything up. In the case of the same compatibility I might have to get rid of the 2016 server for the space to be formated. I would actually prefer to use 2012 if it weren't for every step in set up done manually. I just have a little bit of time and that's mostly going to XP in hyper-v because I use a very old office program. One thing for sure. The microsoft licensing service get's a thumbs up 80% of the time.
Also just in case I don't want to mix you up in anything. The subject has changed. Evacuate the building!
Well I can say that this operating system will not hurt me. And I can sure leave you alone for now. But, maybe we can agree that this will outlast the NUC system in question. And I confirmed the other thing in question was the SGX installation. I might just be missing the chipset. I have to restart.
Well okay. The network device is obviously wifi. I just hate the unknown devices. By the way. This thing will literally restart in under 7 seconds.
Thanks for the feedback and information provided, that operating system might work, but it is not listed as supported because it has not been tested to work with the NUC. The only supported operating systems are those in the article provided above.
David G
