I have a new Intel NUC 12th generation (NUC12WSBv7 with Windows 11 Pro 22H2 (10.0.22621)). Suddenly it has problem with reboot. When selecting reboot in Windows it says it's shuting down but then the screen goes black for 2 - 3 minuter before the BIOS welcome screen is shown. Then nothing more happens, Windows isn't loaded (or sometimes it starts loading after several minutes). I have to press the power button for more than five seconds to turn off the computer. When powering it on again it takes a few seconds before it shows the BIOS welcome screen and Windows is loaded.
If I instead select shutdown in Windows it is shutdown within approx 10 seconds and the computer is turned off. Turning it on again it loads the Windows so fast that I nearly never have time to notice the BIOS welcome screen.
BIOS version is WSADLV57.0085.2022.0718.1715.
Initially I installed Windows in a minimal setup with only a monitor (HDMI), a USB keyboard and USB mouse. After upgrading and installing some features it worked fine, quick reboot. Then I moved it to a new place with two HDMI monitors, Bluetooth keyboard and mouse, Logitech Brio webcam and Jabra headset.
I also had major problems with Windows Update. It failed with installing a lot of Intel drivers (some twice, some different versions of the same driver). The error code suggested that drivers was already installed. After a lot of tries I finally got Windows Update to stop trying to install those drivers. Intel Driver & Support Assistant doesn't list any required updates.
I'm stunned. I don't know what "Windows reboot" does to the BIOS but it seems to break the reboot cycle of the computer. It's like the power is never turned off on the computer.
Hello matsovef,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 12 Pro Board NUC12WSBv7.
1. Have you noticed any errors or blue screens of death?
2. Have you tried to reinstall Windows?
3. Have you performed any changes to the BIOS?
4. Have you presented any other issues with Windows?
Deivid A.
After trying out a number of suggestions found on Internet I got one solution that worked. I used Advanced startup in Windows 11 and when the computer restarted I choosed Troubleshoot -> Advanced options -> Startup Repair. I don't know what it did but after that Windows restarts without problems. Hopefully it will continue to do that.
Thanks for your response,
Mats-Ove
Hello matsovef,
We are glad to hear that the issue seems now to be solved. However, as you mentioned that you are not sure whether or not it is completely fixed, I will keep this thread opened just in case the issue reappears. Let us know if you face any issues.
Jean O.
Hello matsovef,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
I've just installed 2023-01 kumulativ update for Windows 11 version 22H2 without any problems during the restart so I guess it's resolved.
Mats-Ove
Hello matsovef,
Thanks for the confirmation provided. I am glad to know that you were able to install the kumulativ update for Windows 11. I will proceed to close this thread since you fix the issue, however, you can open a new one in case that you need further support or if you face any issues with our products.
Thanks for your time and comprehension.
Deivid A.
