This question is relevant for those who are familiar with the Precision Time Protocol (PTP) or IEEE-1588v2.
I have a simple PTP setup:
[Master] <--- [2 meters cable] ---> [Slave]
There are no devices or switches between master and slave - only an ethernet cable.
The Master is a NUC PC with I218-V NIC (which supports PTP and HW timestamping).
The Slave is a device that has been tested against other Masterssuch as Intel NIC I210 and Intel 82574L, and it worked well.
However, with the I218-V there is an issue that few seconds after starting with heavy network load the path delay is getting smaller.
With no traffic (only PTP traffic), the path delay is about 7-8 usec.
Under heavy traffic, the path delay (after about 10-15 seconds) start decreasing till it reaches about 0.8 usec and then it stabilized there (as long as I keep on the heavy traffic load).
Autonegotiate: off
RX: off
TX: off
EEE status: disabled
Tx LPI: 17 (us)
Supported EEE link modes: 100baseT/Full
1000baseT/Full
Advertised EEE link modes: 100baseT/Full
1000baseT/Full
Link partner advertised EEE link modes: Not reported
Hello JosephMatan,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. What is de model of the NUC that you are using?
3. Are you using the device in a server environment?
Deivid A.
Hi Deivid,
1. The output file of the System Support Utility tool is attached (see nucpc2.txt).
2. The model of the NUC is NUC5i7RYH.
3. Not sure I understand what do mean in server environment. My NUC is running Ubuntu 18.04 Desktop. Is that answer your question ?
Please let me know if you need more details.
Joseph
Hello JosephMatan,
Based on your report (as well as the reply), I noticed that this product is discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
- https://www.intel.com/content/www/us/en/support/discontinued-products.html
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Hi Deivid,
I didn't find my product in the discontinued product link you've sent me.
Are you sure I'm using a discontinued product ?
Joseph
