Intel® NUCs
12120 Discussions
a bootable device has not been detected
jarauz03
Tengo un NUC8i7BEH en la versión 0083, según dice la pagina es la versión mas reciente, no detecta el ssd nvme de 1TB, ni el ssd de 2,5" de 1TB.
Saque ambas unidades y las probé en adaptador y ambas funcionan correctamente, alguien me pudiera ayudar por favor.
Adjunto fotos.
Gracias.
Saludos.
AndrewG_Intel
Hello jarauz03
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool.
We understand that you tested both disks using an adapter? Do you mean an M.2 or SSD enclosure attached to another computer?
Please try the following steps:
1- Check if the drive is detected in the BIOS under Advanced > Boot menu, check Boot Drive Order.
2- Load BIOS defaults:
  1. Press F2 during start to enter BIOS Setup.
  2. Press F9 to set BIOS default values.
  3. Customize any BIOS settings, if desired (optional).
  4. Press F10 to save and exit BIOS Setup.
3- Have you checked if the drive is detected if you boot from a USB thumb drive? For instance, a Windows® installation media USB drive?
4- Make sure the M.2 drive is properly connected and well oriented in the connector. If you use a SATA drive inserted into a daughter card, make sure the SATA power and data wires are connected to the board. If your NUC is only equipped with one SATA wire, check that it's fully inserted to the connector on the board. If you have added thermal tape to the disks, please review if this may be affecting proper connection.
5- If possible, test with different M.2/SSD drives.
6- Finally, try a BIOS recovery following the steps in this link. We recommend the BIOS Recovery by Security Jumper method:
https://www.intel.com/content/www/us/en/support/articles/000005636/intel-nuc.html
Andrew G.
AlHill
AndrewG_Intel
Hello jarauz03
We would like to know if you were able to review our previous post. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
jarauz03
Hello thanks for the support, problem solved
AndrewG_Intel
Hello jarauz03
Thank you for your response. We are glad to know that the problem is solved. We will proceed to close this thread now but if you need any additional information, please submit a new question as this thread will no longer being monitored. It has been a pleasure to assist you.
Andrew G.
n_scott_pearson
Super User Retired Employee
n_scott_pearson
@Lyons,
This is an old conversation. Please start a new conversation for your issues using the Ask a Question button on the main Community scene. Be more detailed in your explanation.
