i can´t this driver "bt_22.40.0_64_win10.exe" silent install with cmd.
bt_22.40.0_64_win10.exe -s
bt_22.40.0_64_win10.exe -q -s
does anyone know?
BS
Bernhard
Hello @bernharddreher
In order to assist you with the proper information, could you please provide us with the following details?
1- The link where you are downloading the driver from?
2- What does happen when you run those commands? What is the output? For instance, does it show any message or error?
3- An Intel® System Support Utility (Intel® SSU) report to gather more details about the system:
- Download and run the Intel® SSU and save the application on your computer.
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
- Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
I got the msi driver download
I was able to install this silently.
Problem closed.
BS
Bernahrd
Hello bernharddreher
Thank you for your response. We are glad to know that you were able to install the driver silently using the MSI* driver. Since the problem is solved now, we will proceed to close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
