Intel® NUCs
Support for Intel® NUC products
12759 Discussions
can i replace my ac3168 wifi bt interface with a ac9260 running win 10 64bit intel i7 7th gen?
hemlock110
n_scott_pearson
Super User Retired Employee
Provided this isn't an OEM version of the AC3168, yes, you should be able to upgrade to the AX9260. Personally, however, I would be replacing it with an AX200 (WiFi6) or an AX210 (WiFi6e) card.
Hope this helps,
Jean_Intel
Hello @hemlock110
If I may interrupt here, the best practice for your query is to consult the motherboard manufacturer and check if the ac9260 is listed on the wireless cards compatibility list, as well as steps for the proper installation of the wireless card. Not all systems are capable and compatible to work with all wireless cards, and only the system manufacturers will have more control and understanding of their system capability.
I hope you find this information useful.
Jean O.
Jean_Intel
Hello @hemlock110.
I hope you are doing fine.
We have not heard back from you, so we will close this thread. If you need any additional information, please, submit a new question as this thread will no longer be monitored.
Best regards.
Jean O.
