Intel® NUCs
Assistance in Intel® NUC products
12986 Discussions
can i uninstall intel graphics control panel if i have intel grphics command center and if yes whats the procedure to uninstall intel graphics control panel
AVali5
LeonWaksman
  1. Open Device Manager.
  2. Open Software Components
  3. Right click on Intel Graphics Control Panel and then click on Uninstall device - check the "Delete ..." option.
Leon
LeonWaksman
  1. Yes, you can uninstall the Intel Graphic Control Panel (IGCP). The intel Graphics Command Center replaces the IGCP.
  2. In order to uninstall the IGCP, open Apps and Features (in Windows Setting), click on Intel Graphic Control Panel and then click on Uninstall.
Leon
AVali5
i don't have intel graphics control panel in my apps and features
LeonWaksman
Can you find the IGCP in Start Menu under letter "I"? If not, where you see the IGCP?
Leon
AVali5
I can't find it anywhere intel graphics command tells me to uninstall IGCP when i open it
LeonWaksman
Leon
AVali5
Thanks I found and uninstalled it will it cause problem after uninstalation ​
LeonWaksman
It will not cause any problem after uninstalled. In case that you want to install it again, you may download IGCP from Microsoft Store. This version can be installed together with IGCC.
Leon
venison
I can't uninstall graphics control panel using this method because after unistallation it reinstalls immediately. Does anyone have solution for that?
