Intel® NUCs
Assistance in Intel® NUC products
12986 Discussions
connection issue from nuc to tv
ichan9
hey i need support in one thing . I want to connect my intel nuc to my tv monitor using ethernet cable to hdmi converter , and its not showing any display or anything in my tv . Wanna ask , is it possible to connect my nuc to tv using hdmi to ethernet cable ?
Trial-Member
New Contributor III
Hey @ichan9​,
Can you please give more details?
NUC Model? BIOS & Driverss are up to date?
Any information about the Enthernet to HDMI-Converter?
Any information about the TV used?
Have you tried using a PC-Monitor? And if yes: What was the result?
ichan9
hey yeah . Nuc model ' NUC7I3BNH' all drivers are up to date .
TV used is samsung tv .
PC monitor can detect but my Samsung tv cant detect using ethernet cable .
Trial-Member
New Contributor III
If the connection to a monitor works, but not to the TV, then the cause seems to be more in the area of the TV.
Question: Which model is the TV? What resolution and frame rate have you set on the NUC?
Can you try to access the NUC via RDP? Will the TV be displayed as an output device in the control panel?
LeonWaksman
  1. Are you trying to connect Ethernet socket (input) on your NUC to the HDMI input on your TV? For what purpose? What you want to achieve? Video can't be transmitted through Ethernet connector from your NUC.
  2. The usual way to get video from your NUC to your TV, is by connecting the HDMI output (located on the back panel, just on the left of the Ethernet socket) to the HDMI input on your TV. For this connection, use High Speed HDMI to HDMI cable.
Leon
ichan9
hey leon , theres two connector , 1 receiver and 1 transmitter , so the nuc side . i plug the ethernet cable into hdmi adapter and enter hdmi port . for tv , ethernet cable to hdmi connector and enter hdmi 1 . cause my nuc and my tv is far away . in my shop , i want to display my customer display screen . so its impossible to pull hdmi that far . the only way is to pull ethernet cable and connect hdmi adapter .
LeonWaksman
O.K. that can be done.
  1. What is the distance to your TV (the length of the cable) ?
  2. Are you using CAT6 type cable or CAT5 type?
Leon
David_V_Intel
Hello ichan9, Thank you for posting on the Intel ® communities. Were you able to check LWAKSMAN's post? Let us know if you need any more help. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
David_V_Intel
Hello ichan9, Please contact us if you have any additional questions. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
