Hello
i use a Intel NUC10i7TNK and we would use a USB C-HDMI Adapter for a 2nd Display. In the system manager is allways a fail in detection verification process. Also it isn't possible to update the thunderbolt software update.
what can we do? thx for your support!
an ssu scan is attached
Hello TL-SEEL,
To better assist you please provide the following information.
-Have you tested a different cable/adapter?
- Were you able to have a normal/expected performance with this configuration before? If yes, was there any recent change related to the point when the issue started?
- Did you try using a straight-through connection (e.g. HDMI-to-HDMI, DVI-to-DVI) with a single cable for both monitors?
-Is the issue the same if you test only one display at a time or if you swap out the displays testing "other video ports" on the NUC?
- With both displays connected to the NUC, please provide a Report for Intel® Graphics Drivers following the steps on the link.
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
-Were you able to check the Thunderbolt option in BIOS:
Note: If you didn’t please follow the steps below to do it.
Steps:
- Press F2 during boot to enter BIOS Setup.
- Go to Advanced > Devices > Onboard Devices.
- Check that the Thunderbolt Controller is enabled.
- Press F10 to save and exit BIOS Setup.
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Hello Victor
my answers tp your questions:
tested three adapters
2 different adapters from i-tec
C31DUAL4KHDMI | i-tec USB-C 3.1 Dual 4K HDMI Video Adapter | i-tec (i-tec.pro)
C31METALDP60HZ | i-tec USB-C Metal Display Port Adapter 4K/60Hz | i-tec (i-tec.pro)
> still not working
USB to Dual HDMI Adapter - 4K - USB Video Adapters (startech.com)
> working fine with 2 monitors
>Yes normal performance; is a new system setup build on november 2020.
yes with both monitors. is working fine on the hdmi port with multiple diffrent cables
there is no diffrence
>attached
Thunderbolt Driver is enabled
Thx for your support!
Kind regards
Oliver
Hello TL-SEEL,
Based on the issue that you're experiencing please try the following:
- Reinstall the latest thunderbolt driver
How to install
Double-click Thunderbolt™ Software Installer.exe.
Note: The Thunderbolt Control Center should load automatically after the driver is installed and if you're connected to the Internet. If it doesn't, you can download it from the link down below.
Note: The Thunderbolt Control Center allows you to approve and manage Thunderbolt
devices.
-Please try to reinstall the USB Type C Power Delivery Controller
-Please try the following driver by performing a clean installation of it and let us know if the issue persists
Version: 27.20.100.9168
Clean Installation of Intel® Graphics Drivers in Windows® 10
- Complete a BIOS recovery
Instructions
*There are two methods in the link above please try the power button menu one. If the problem persists, continue to the next step.
Latest BIOS:
- Restore BIOS factory defaults:
- Press F9 to set factory defaults.
Victor G.
Hello TL-SEEL,
Please let me know if you need further assistance.
Victor G.
Thx Victor
I'm looking with a college of our company it. The problem is in my eyes the thunder bolt software. we can't install this in a proper way > critical abandon.
We have a temporar solution for our events and we will look later to fix the problem.
Regards TL-SEEL
Hello TL-SEEL,
We understand that you have found a temporary solution; however, please bear in mind that even though there is always a possibility for the port to be damaged or the software not be working as it’s supposed to, when we talk about adapters there is always a possibility that those can cause no display issues or even a flickering display; therefore, in case you want to give it a shot in the links down below you will see the cables and combinations supported for this unit, I would recommend if possible to try them out and let us know if the port reacts differently if not we can check a different approach from our end.
Cables and Video Adapters for Intel NUC Display Connections
https://www.intel.com/content/www/us/en/support/articles/000056401/intel-nuc.html
Note: You will see in this link all the cables we have tested with our NUCs and in regard to a USB-C - to HDMI adapter, that one hasn’t been validated; therefore, limitations and issues may occur.
Multiple Display Configuration Options for Intel® NUC Kits NUC10i7FN, NUC10i5FN, NUC10i3FN
https://www.intel.com/content/www/us/en/support/articles/000056438/intel-nuc.html
Note: On this link, you will see the recommended configurations you just need to bear in mind that we are talking here about straight connections only from NUC port to monitor port.
It is worth mentioning that even though some adapters might not be recommended we understand that third party brands will develop different options for NUC users and if you want you can use the following tool to find the ones that we have validated and check with the different manufacturers to see which one would you like to test.
Intel® Product Compatibility Tool
https://compatibleproducts.intel.com/
Note: The path to finding them is the following: Intel® NUC >MINI PCS > NUC10i7FNKPA > Cables, Thunderbolt™ and USB Type C Devices, or Adapters and Dongles.
Victor G.
Hello TL-SEEL,
Victor G.
Hello TL-SEEL,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Victor G.
