Intel® NUCs
12315 Discussions
does anyone have drivers for the intel dp35dp motherboard?
KWill27
AlHill
What driver do you need, and for what OS?
Doc
KWill27
I'm looking for the chipset, network, modem and any others that supports the motherboard. I'm using window 7
AlHill
Not asking for much, are you? Ok, Windows 7 is dead, so you want help to build a fresh W7 machine.
Here is the LAN driver for your board:
https://downloadcenter.intel.com/download/18713?product=34460
I do not see where your board had a modem, so you are on your own with that.
For the chipset inf, I cannot verify the integrity of the install file, and have attached it for you. Use at your own risk.
You should seriously forcus on using windows 10, instead of windows 7. All the drivers would be there for you for this 2007 board. It is 13 years old, and I would not be surprised if you started seeing component.
Doc
KWill27
Thank you so much.  As you know the mobo dp35dp is a very old board.  I'm using it down in the basement ET Shop to play with a Raspberry Pi  and to lookup electronic components part numbers.   I have more powerful computers, but for what I using it for will be good enough.  I truly thank you for the help.  could not find them online without paying someone for them.  I used to have the driver but I must have misplace them.  Again thanks.
