Hello echen8195,
In order to better assist you, please provide the following information:
- Are you using an Intel NUC? If that is the case, please provide the model of it.
- Do you have any external devices connected to your system?
Be aware that the question marks are normal when referring to "Other devices" section in Device Manager.
Steven G.
I am sorry, we cannot to anything with a capture containing non-English text.
I presume that you are installing the Intel Bluetooth driver, not trying to use the Microsoft driver?
Hello echen8195,
Steven G.
Hi, Steven:
my NUC is model:NUC8HV SN:BTHN911001KF, SA : J71485-504
Thanks for your answer, then I know the question mark isn't a problem, some Bluetooth's connections caused it (like Sound Core Life P2)。
My problem is cleaned, thank you, and Mr. n_scott_pearson
Thank you for your response.
I am glad to know the information provided helped. Since the thread is now solved, we will close it.
If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
