Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
eGPU compatibility with NUC7I5BNH
I have NUC7I5BNH and am planning to add an external GPU (eGPU) for machine learning purpose. Specfied below is the eGPU case and GPU am currently exploring. I was wondering if these are compatible with the same. Any help is sincerely appreciated. Thanks.
Option - 1
- Akitio Node eGFX box. I can't see NUC7I5BNH in their compatibility list (https://www.akitio.com/information-center/node-gpu-compatibility AKiTiO Node GPU & Host Compatibility Chart | AKiTiO )
- NVIDIA GeForce® GTX 1060 G1 Gaming 6GB
Option - 2
Aorus GTX 1070
Tags (1)
Community Manager
Hello heshdan
Thank you for joining the community.
Looking into the tested peripherals for the NUC7i5BNH I did not any of the eGPU you can review that information on the following link
http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...
Please let us know the outcome of the of the test that you perform
Leonardo C.
Community Manager
Hello heshdan
I was checking your case and would like to know if you were able to set up the configuration, if not seems that is a compatibility issue
Leonardo C.
