Hello at all NUC Fan
I will buy a eGPU for my NUC, but i had no expiriance with eGPU
someone has already configured this?
what would you recommend
Thank You for Feedback
Roger
Take a look in products validated by Intel (see the the Thunderbolt and USB C devices category) http://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC# Four product tested and three validated as compatible.
Leon
Hello Leon
you mean when I check
Thunderbolt 3 External Graphics Dock
GTX 1070/GTX1080
Intel Validated
Then its onlx GTX1080 Cards ?
Cheers
Roger
Am Mo., 28. Okt. 2019 um 14:32 Uhr schrieb Intel Forums <
supportreplies@intel.com>:
- Yes, you are right, only one from the listed enclosures (Aorus GTX 1070/GTX1080), includes GIGABYTE Geforce GTX 1070 MINI ITX Graphics card GV-N1070IXOC-8GD.
- The other two: Akitio Node and PowerColor Devil Box , are enclosures only (you need to install Graphics Card in this enlosures)
- In the Akitio Node, you may install one of the listed compatible Graphics Card: https://www.akitio.com/information-center/node-gpu-compatibility#gpu (this was tested by Akitio and not by Intel).
- The PowerColor Devil Box is also certified to work with AMD and NVIDIA Graphics Card.
Leon
Hi Leon
Thank you for your Feedback, thats no so funny, I was thinking I can Buy every Graphics Card
Example RTX 2080 i and normal enclosure, tha i can buy here
Maybe its working but when I spend 1800 and im not sure.. its not funny ;-)
Cheers
Rog
Am Mo., 28. Okt. 2019 um 18:33 Uhr schrieb Intel Forums <
also the Card is old, GTX 1080, thats sad, so im not sure works with a new one or not..
Cheers Rog
I can see that RTX 2080 (so, many other cards), was tested in the Akitio Node.
Leon
Hi Leon
ok thank you so I will check wich one I can Buy here at Switzerland ;-)
Cheers Roger
Am Di., 29. Okt. 2019 um 09:41 Uhr schrieb Intel Forums <
Hi Leon
found also good one
*Gigabyte *Aorus GeForce RTX 2070 Gaming Box (eGPU (Grafikkarte)
But not sure its working or not... Problem here is the Case... but I gus a
lot of other is working.. but risc to Buy 1k$ and then is not ;-)
Cheers
Hi I had buy
Razer Core X Chroma
MSI GeForce RTX 2070S VENTUS OC (8GB, High End)
Installed the new GeForce Driver 441.08
But the Card is allwasy Stoped with Code 43
Had n o Idea to solve
cheers
rog
- I don't have idea how to solve it, neither. You should ask NVIDIA what this error code indicates.
- You may try to install the latest Radeon Driver version 19.9.2. I'm using this driver and it is working well. However I don't know if this may help in this eGPU problem: https://www.amd.com/en/support/kb/release-notes/rn-rad-win-19-9-2.
Leon
