Intel® NUCs
Support for Intel® NUC products
12753 Discussions
how do I get Windows to recognize the replacement HD in my RAID? The BIOS shows 2 HD but not windows
ESamp1
n_scott_pearson
Super User Retired Employee
You will have to provide is with a *lot* more information before we'll be able help you with this.
ESamp1
Please tell me what you need and I will supply. 1 of the 2 drives went bad and I simply replaced it. It’s RAID 1 so I wouldn’t lose data. After I replaced the hard drive the system runs but it does not recognize the new HD. The BIOS shows the 2 drives but Disk management does not.
n_scott_pearson
First of all, please download and run the Intel System Support Utility for Windows and save the report to a file. Then, using the paperclip icon below the edit window, upload and attach this file to a response post.
Second, explain step-by-step what you have seen and done, starting from "My RAID array was working fine...".
ESamp1
I got a message that a HD was bad, so I replaced it with like-kind from WD. I removed bad unit and inserted new unit. At that point I noticed that even though the BIOS shows 2 HD W10 does not. I was set up for RAID 1 to allow for data safekeeping. I have attached the report that you asked for. Marty
n_scott_pearson
Did you remove the failing unit from the array? Did you add the replacement unit to the array? Sounds like, no, since it is sitting independently right now.
ESamp1
You are correct, I have done neither since I’m not sure how to do that and I don’t want to lose the data on the the drive that W10 recognizes. Can you walk me through how to finish this project?
n_scott_pearson
You do the same thing that I would have to do to tell you the answer, namely open the manual and read it: Intel Rapid Storage Technology (RST) User's Guide.
ESamp1
OK, I have done what you suggested. Wish me luck… *Marty*
n_scott_pearson
If you've read the manual, you can hang around and help other people!
