- I hardly understand your question. Your NUC is equipped with two video output ports: mini HDMI and mini DP.
- In your question you are giving the answer. If the first monitor has only DVI input, you may use mini DP to DVI cable. One like this for example: https://www.amazon.com/Cable-Matters-Mini-DisplayPort-Black/dp/B00DJCB83O/ref=sr_1_3?crid=2U0GNL0WBK... . If the other monitor has HDMI input, use mini HDMI to HDMI cable. One like this for example:https://www.amazon.com/AmazonBasics-High-Speed-Mini-HDMI-Adapter-Cable/dp/B014I8UEGY/ref=sxin_2_pb?k...
- See also technical Product Specification, page 24-25 https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC5i5RYB_NUC5i3RYB_Tech...
Hope this helps
Leon
Hello LPodw,
Thank you for posting on the Intel ® communities.
Please keep only one thread related to this issue, you will get the assistance there:
https://forums.intel.com/s/question/0D50P00004OxjVs
LWAKSMAN, thank you very much for assisting.
David V
Under Contract to Intel Corporation
