Hello Support,
I have a problem with a NUC10FNH booting iSCSI with fixed address.
If I use DHCP it works fine.
I have installed the latest firmware but old firmware have the same problem.
Please help.
Giuseppe
Hello @MartinoHelpdesk
In order to check this further, could you please provide the following information?
1- Clear/HD pictures from the BIOS settings, for instance:
- Advanced > Add-In Config
- Boot >> Boot Priority >> Network Boot
- Boot >> Secure Boot
2- Please elaborate more on how you are deploying/setting up this configuration and provide detailed replication steps.
3- Could you please provide more details regarding what you mean when you mentioned "you have tested the latest and old firmware"? Do you mean BIOS firmware or any other?
4- Is your NUC currently running an operating system from internal storage? If yes and if running Windows®, please run the Intel® System Support Utility (Intel® SSU) and attach the report to this thread to gather more details about your system.
- Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
Note: To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Just in case, here is the Intel® SSU version for Linux*: https://downloadcenter.intel.com/download/26735/
Andrew G.
Hello Andrew ,
Attach you see all the HD picture of the BIOS setting.
This NUC is a diskless system.
So I can’t install software.
Giuseppe
Hello Andrew ,
2- The HD picture attach you see the settings related to Iscsi setting.
If I changed to a fixed IP-address it will work anymore.
We see no connection made to the server.
3- Yes I mean BIOS firmware.
Giuseppe
Hello MartinoHelpdesk
Thank you for all the information provided.
Please allow us to check this further and we will be posting back in the thread as soon as we have more details to share or if more information is required from your environment.
Andrew G.
Hi MartinoHelpdesk,
We are still looking into this issue and after checking with the BIOS engineers, they are requesting the following information:
- Server IP settings
- Are you using Synology NAS and Synology DiskStation Manager?
- Can you provide us with the target information tab? There should be an iSCSI target created and there should be a tab with the target information (Target name, IP address, Gateway, Lun #, etc).
- Does the iSCSI boot work with any other device? Can you provide some details?
Ronny G
We are checking this thread and we would like to know if you were able to review our previous post (Ronny's post). If you need further assistance, please do not hesitate to contact us back.
Andrew G.
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
Hello Andrew,
For now we don’t have any NUC10FNH.
I have order some and I hope to receive them next week.
Giuseppe
