Intel® NUCs
12111 Discussions
integrated Digital microphone array (DMICS) doesn't work after update Realtek drivers
LLiu37
the integrated Digital microphone did worked when I install Win10 at first, but if I install the "Realtek* High Definition Audio Driver for Intel® NUC Kit NUC8i7HNK, NUC8i7HVK" version 6.0.1.8323 provided, the microphone stopped working, I tried several times ,same results.
So i had to uninstall intel driver and then install the realtek HD audio driver from the realtek's own website, http://www.realtek.com.tw/downloads/downloadsview.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownT... http://www.realtek.com.tw/downloads/downloadsview.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownT..., it really worked and saved my microphone back, but without the Realtek HD Audio Manager, anyone surfer same problem ? How can I got the microphone and the realtek audio manager worked same time?
Ray_W_Intel
Can you confirm which version of the BIOS you are running on your platform?
You can do this through system information in windows by pressing start button and typing system information and pressing enter. You can also check in the BIOS itself by rebooting the system and entering BIOS through the F2 key prompt.
LLiu37
have upgraded bios to the newest version. 0040
RRAND6
Yes, you are right.
I followed the link and then downloaded the 64-BIT driver for Windows 10 x64 April 2018 edition (ISO downloaded from Microsoft website and then activated with my key).
NOTE: Initial install was with Intel supplied drivers, then I downloaded and replaced the drivers.
It worked perfectly.
The supplied driver FOR NOW (JUN 12, 2018) breaks the Digital microphone array (DMICS) connectors (internal).
Makes a lot of difference as the microphone array is spatial and catches great.
