Intel® NUCs
Support for Intel® NUC products
12739 Discussions
intel NUC11PAHi7 after (BIOS 0043) RAM error
ATH
After updating the bios to 0043 the lower ram socket does not work at all, however, the upper is working fine
I have tried swapping the memories and every possible way to make it work with no luck
please intel fix this issue as soon as possible
CHECK THE ATTACHED VIDEO FOR MORE DETAILS
Jean_Intel
Hello @ATH.
To have a better understanding of your issue, please provide me with the following:
  • Was there any other change besides the BIOS update?
  • Have you tried another memory module?
  • Make sure the contacts on the memory and the socket are clean.
  • Create a report using the Intel System Support Utility (Intel SSU)
 • Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html)
• Open the application and click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View".
• Click on the menu where it says "Summary" to change to "Detailed View".
To save your scan, click on "Next", then "Save".
I am looking forward to hearing from you.
Jean O.
Jean_Intel
Hello @ATH.
I hope you are doing fine.
Jean O.
Jean_Intel
Hello @ATH.
We hope you are doing fine.
We have not heard back from you. So we will close this thread, if you need any additional information, please submit a new question as this thread will no longer be monitored
Best regards.
Jean O.
