Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11992 Discussions
intel nuc8i7hvk green rather than pink Ubuntu 16.04 screen (HDMI ports)
jareilly
0.jpgAfter installing 16.04 (Ubuntu v4.15) I started getting "green rather than pink screen" (colors reversed) from my nuc8i7hvk on all hdmi ports. I powered off the display and got the same. I plugged my laptop into the display via HDMI and it was fine. I then plugged the NUC into the display and it also was then finally fine...
LeonWaksman
Linux is not supported on NUC8i7HVK. However there are reports that the version 18.10 of Ubuntu was successfully installed and tested on this NUC: https://www.forbes.com/sites/jasonevangelho/2018/10/22/intels-hades-canyon-nuc-and-ubuntu-linux-18-1...
Leon
LeonWaksman
Leon
jareilly
Thanks! I updated to 18.04 and am now going to update to 18.10 (it sounds quite solid for this nuc version! nice!) or 19.04. If I go off the Ubuntu LTS rails, I guess I may give 19.04 (Ubuntu power efficiency should be improved) a try just to see if that succeeds well. Thanks for the tips!
