Intel® NUCs
Assistance in Intel® NUC products
13306 Discussions
latest Graphic driver(6912) is not good running than older(6709), on OpenToonz software.
NEKOmaru
I'm checking to some Intel GFX drivers by graphic applications.
(my env : windows 10 pro 1903, NUC8i5, 32GB ram)
version 6912, 6890, 6861 : NG (Opentoonz windows is broken everytimes)
version 6709, 6708, 6618, 6519 : GOOD (Opentoonz is good running)
so I report this thing.
and I attach the screenshot later.
Wanner_G_Intel
Hello NEKOmaru,
We tested Opentoonz Ver1.3 on Intel® NUC Kit NUC8i5BEK running the following configuration:
BIOS 0073
Windows* 10 1903 May 2019 Update
Driver version 25.20.100.6519
Driver version 26.20.100.6912
We were unable to replicate the issues reported on this thread. Other Community peers have not reported similar issues with this or other software.
1. Try reinstalling the application.
2. This seems to be an operating system or software corruption issue. Although reinstalling the operating system may take some time, this may fix this issue.
3. If the problem persists, we recommend contacting the developers of the application for further support.
Wanner G.
A Contingent Worker at Intel
NEKOmaru
Wanner_G_Intel
Hello NEKOmaru,
Thank you for posting on this Intel Community.
To better assist you,
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report to this thread to review your system configuration.
1. Download the Intel® System Support Utility and save the application in your computer.
2. Open the application and click "Scan" to see system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
3. To save your scan, click Next and click Save.
2. Please provide a detailed description of the issue.
Wanner G.
NEKOmaru
Hello Wanner G,
thank you for your reply and I uploaded the files right now.
I wish that help us.
in my NUC, newer driver wasn't working well. (6912, 6890, 6861)
NEKO😺
NEKOmaru
posted a file.
Wanner_G_Intel
Hello NEKOmaru,
Thank you for your response.
It seems that you are running generic driver versions for the graphics controller. We recommend using the drivers customized for your unit instead. Try performing a clean installation of the graphics driver in case older drivers are causing system conflict. This time, try using the following driver version for your Intel® NUC.
1. Download the latest driver for your unit: 26.20.100.6912
2. Disconnect your unit from the Internet to prevent Windows* Updates from installing any other driver.
3. Uninstall the DCH driver and the Intel® Graphics Control Panel from Control Panel > Programs and Features.
4. Restart the computer.
5. Make sure the 'Microsoft Basic Display Adapter' is listed under Windows* Device Manager > Video adapters. If not, repeat steps 2 to 4.
6. If the adapter continues to be listed as ‘Intel HD Graphics’, and no other Intel® Graphics driver is listed under 'Programs and Features' for removal, then it means Windows* has switched to a previously installed Legacy driver. At this point, we can remove Legacy drivers from Device Manager:
6.1.1 Right-click on 'Intel HD Graphics' or similar, and select 'Uninstall Device'
6.1.2 In the pop-up window make sure 'Delete the driver software for this device' is checked.
6.1.3 Click on 'Uninstall'.
6.1.4 Restart. (Repeat steps 6.1.1 through 6.1.4 until the device gets listed as 'Microsoft Basic Display Adapter')
7. Install the driver that was downloaded on step 1.
8. Restart the computer.
9. Enable your Internet connection.
10. Download the Intel® Graphics Control Panel from the MS Store if it was not downloaded automatically from the Internet.
Check Windows* 10 updates, scan and apply all of them.
Wanner G.
NEKOmaru
Hello Wanner G,
thank you for your support.
and I did that re-install procedure then but this issue was not gone..
(this time, I re-installed ver.6912 and 6890.)
so I installed ver.6861(old one) just now.
could you test Opentoonz in your department? because another application was not trouble.
please and thank you.
NEKO😺
Wanner_G_Intel
Hello NEKOmaru,
Thank you for the update.
We will attempt to replicate this issue in-house.
Is Opentoonz free of charge?
Could you please also post the application you are not having issues with?
Wanner G.
NEKOmaru
Hello Wanner G,
Yes, it is free (open sourcs) software.
Opentoonz Ver1.3
https://opentoonz.github.io/e/download/opentoonz.html
Sample Scene DL
https://opentoonz.github.io/e/download/sample.html
Yes, it's DaVinci Resolve 16 (beta). and I'm using the free version. it running perfectly on NUC8i5.
https://www.blackmagicdesign.com/products/davinciresolve
I checked some Intel Graphics driver.
the Fusion page in DaVinci apprication was crashed every times when Intel Graphics Driver ver 6519 is installed. (attached the IMG)​
NEKO😺
Wanner_G_Intel
Hello NEKOmaru,
Thank you for sharing this information.
We will attempt to replicate this behavior and update this thread as soon as possible.
Wanner G.
Wanner_G_Intel
Hello NEKOmaru,
BIOS 0073
Wanner G.
NEKOmaru
Hello Wanner G,
Thank you so much for your great supports. and I am glad to get the answer.
so I clean re-install windows OS later.
Yes, I reinstalled Opentoonz apprication but it was not fixed.
thank you Intel support team!
I update the comment when clean installed the OS.
NEKO😸
NEKOmaru
I have been reinstalling windows 10 but this trouble was not fix.
JWein6
I am having a similar problem with Intel NUC 8i5BEK1. I have used the Intel Driver & Support assistant and I continually get a "This installation package is not supported by this processor type" on the current and immediate past version of the graphics adapter. (26.20.100.6912 and 25.20.100.6519).
How do I remedy this issue?
JWein6
windows 10 pro 10.10.1563 bios 0073.2019.0618. I also am unable to use the USB-C port to display an additional monitor.
NEKOmaru
hi JWein6,
this thread was seems to closed (I think intel stuff's support was finish.). so let's post the new thread the issue.
I think this procedure is better for the graphic driver re-install.
https://forums.intel.com/s/question/0D70P000006RXKMSA4
and I did not error on my PC "This installation package is not supported by this processor type".
my NUC8i5 bios is same as yours. #0073.
cat
NEKOmaru
update: NEW Driver 7529 running well. trouble was gone.
I installed new GFX driver today. (GFX-Win10-26.20.100.7529) then I did not find the trouble. I'm happy.
thank you Intel.
-neko meow
