Intel® NUCs
Assistance in Intel® NUC products
12947 Discussions
lost serial ports
liv-in-sky
hi, maybe someone could help me - I'm using a nuc NUC8i5BEB. two weeks ago I was able to flash (e.g. arduino,...) over the com-port. now the com-ports disappeared.  I only know, that windows (1909) made some updates.
- I have tried to install new ports with the device manager - error code 10 - not able to start
- I have installed all latest updates for the nuc (bios inc.)
how can I get back the com-ports
n_scott_pearson
Super User Retired Employee
AFAIK, there is no externally-exposed COM port in the BE NUC. Are you sure this was what you were using? If so, how did you connect the external flash programer?
liv-in-sky
hi - thanx for your reply - you are right - there are no com-ports - I meant com over usb.
I have already find a solution and have deleted the drivers. Now everything is working again
