is this model Intel® NUC Kit NUC7i7BNH have build in microphone?
how to connect one?
Yes, as Scott mentioned you can use the build in Digital Microphone Array. See para. 2.2.4.11 on page 58 and figure 22 on page 80 in Technical Product Specification https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC7i5BN_NUC7i7BN_TechProdSpec.pdf
In order to use this microphone it should be enabled in Bios Advanced>Onboard Devices. In addition it should be assigned as default recording device in Windows Audio Panel.
Leon
Your nuc does have a mic input. Look at page 31 of the technical specification:
Doc
thank u for your answer.
but- how i can connect speakers and microphone at the same time?
i put a spliter - but it not working
You can use BT speakers and a mic from the compatibility list here:
http://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC#
Doc
Actually, the BN NUCs all have built-in stereo microphones; you do not need an external one.
This is good to know. I did not see it in the spec.
Doc
Leon
