Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13496 Discussions
monitor blanks out. drives TV
mehoward
My Nuc6i7kyk began losing monitor contact, slowly at first, now it only flashes occasionally-- but it drives a TV with no issues!
LeonWaksman
NUC drives TV from the same video output? Using the same cable?
Leon
mehoward
different monitors, different cables, same result.  only 1 HDMI output.
LeonWaksman
You may try to connect your monitor with the same HDMI cable used for the TV set.
You may also try to connect your monitor to the miniDP output port or to USB C DP output.
Leon
